inoperative electric step (1 Viewer)
gwyntaxi
1,151
1,047
,Swansea
hymer starline 655
42yearscaravanning&motorhoming
Inoperative electric step
Hope someone can help me with this problem,my vehicle is a Hymer starline 655,year 2005,I parked it up end of December 2014.when I tried to enter it in mid-March 2015,the electric double-step would not come out when i operated the switch just inside the door,it was working perfectly when i parked it up.I've looked everywhere for a possible blown fuse etc,but no joy.There does NOT app
ear to be any relevant fuse on the Electroblok,even though is shown on the man
-ual as fuse no.4,there isn't one position 4 is a sort of white plug-in connector.I
have removed the cover from the motor and pressing the RETRACT part of the rocker switch gives a reading of 13.8v on my multi-meter pressing the lower half of the switch(which sends the step out)gave a reading of zero.so i connect
-ed a spare leisure battery via 2 wires to the red+and black-wires coming out from the motor casing the step began to come out as norm,so I stopped and I pressed switch and the step retracted as norm,so the motor is ok,hasv anyone ever experienced this problem,i've tried every fuse I can find not Knowing EXA-
-CTLY where the correct one really is,would be grateful if any one could offer
some useful suggestions/solutions as I've run out of ideas,many thanks.
gwyntaxi is online now
Q
[URL='http://forums.motorhomefacts.com/newreply.php?do=newreply&p=1342065']Q
[/URL][/URL][/URL][/URL][/URL]
gwyntaxi
gwyntaxi
1,151
1,047
,Swansea
hymer starline 655
SORRY EVERYONE,DON'T KNOW WHY MY PLEA FOR HELP REPEATED ITSELF SO MANY TIMES, I DID TRY COPYING&PASTING IT FROM A DIFFERENT LOCATION SO PERHAPS THAT'S GOT SOMETHING TO DO WITH IT,AND THE FACT THAT I'M USELESS AT ALL THINGS COMPUTING,I'VE TRIED TO ERASE THE EXCESS POSTINGS BUT HAVEN'T GOT A CLUE SO I'LL LEAVE WELL ALONE OR I'LL LOSE THE THREAD ALTOGETHER
53,476
150,189
Hymer's normally use the Schaudt Step Control unit, basically a couple of relay boxes with a current sensor & timer. The ones in our van are EMS 03-3, one will be located near the step in a cupboard or under a draw near the habitation door the other one with either be under the passenger seat (LHD) or near the battery. The one near the battery will have a fuse in-line with it.
gwyntaxi
gwyntaxi
1,151
1,047
,Swansea
hymer starline 655
Many thanks for the tips lennyhb will try them today and see if I can find these elusive fuses,especiall
-y the one near the habitacion door.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Just re-reading your original post (post-post-post-post-post-post!) :roflmto: I notice you were trying to find the fuse on the EBL. Given that there appears to be power to the step motor I doubt the EBL fuse has gone, but offer the following in case it helps.
Not sure what EBL your 655 has, but assuming it's an EBL99 or EBL100, block 4 is the connector for power to the step, heater and frost protection valve.
The fuse for the step is a 25amp unit in the row of fuses (below the connector blocks). It will be labelled 'Grundlicht / Trittstufe'
11,955
16,570
If the step retracted using the switch the fuse is not at fault - it is the same fuse for both directions.
andy63
4,672
15,018
south shields
since 1990
reading the problem , but not knowing the hymer set up , could it not be the rocker switch its self.. you have power on retract at switch. is it not the same supply to the rocker switch for retract and open, you have voltage on retract but not open, suggesting the switch itself is not working.. may have the wrong end of the stick
ta andy
53,476
150,189
ta andy
Hymer use a momentary switch with control boxes. (see my earlier post)
Lindsay
16
10
Ayton, Scottish Borders
Burstner Delfin T625
had a home conversion when kids were young(30 years ago).
Hello gwyntaxi,
Same happened to my step, simple fix was to free off pivot bolts. Try it :)
Aug 4, 2013
1,140
140,227
Oop North
None now 😢
I am not a techi at all but our step sometimes fails to operate and I am pretty sure that it is just dirt sticking after a road trip i just help it a bit by pushing it as I press the button and then it works and frees off ..... Should probably dismantle something but see this old post
Hope it helps.
Feb 27, 2011
14,741
76,072
My Hymer had a microswitch to detect when the step was retracted etc. This got clogged up and the step wouldn't work. I gave it a heavy dose of WD40 and clicked it manually a bunch of times.
This got it working.
andy63
4,672
15,018
south shields
since 1990
just the op used the term rocker switch which made me think conventional I suppose.. if it was momentary it would only require a push button, or so I thought...
ta andy
gwyntaxi
gwyntaxi
1,151
1,047
,Swansea
hymer starline 655
Hi everyone,
I would like to say a big thank you to all of you,for taking the trouble to respond to my request for help,so far I have tried everyone's suggestions',but still no improvement,but I'm gonna keep at it,i've got to,cos the entrance into the van is about 3ft offf the ground,and at the moment I'm using a 3-step stepladder and it ain't doing my hips and knees any good,so thank you all,i@ll keep you posted if and when I get a positive result.gwyntaxi.
gwyntaxi
gwyntaxi
1,151
1,047
,Swansea
hymer starline 655
Hi Jaws, yes that's the same Electroblock 101 as fitted to mine.
