inoperative electric step
Discussion in 'Tech/Mech General' started by gwyntaxi, Mar 29, 2015.
  1. gwyntaxi
    gwyntaxi Funster
    Jun 9, 2009
    173
    64
    waunarlwydd,swansea
    Inoperative electric step
    Hope someone can help me with this problem,my vehicle is a Hymer starline 655,year 2005,I parked it up end of December 2014.when I tried to enter it in mid-March 2015,the electric double-step would not come out when i operated the switch just inside the door,it was working perfectly when i parked it up.I've looked everywhere for a possible blown fuse etc,but no joy.There does NOT app
    ear to be any relevant fuse on the Electroblok,even though is shown on the man
    -ual as fuse no.4,there isn't one position 4 is a sort of white plug-in connector.I
    have removed the cover from the motor and pressing the RETRACT part of the rocker switch gives a reading of 13.8v on my multi-meter pressing the lower half of the switch(which sends the step out)gave a reading of zero.so i connect
    -ed a spare leisure battery via 2 wires to the red+and black-wires coming out from the motor casing the step began to come out as norm,so I stopped and I pressed switch and the step retracted as norm,so the motor is ok,hasv anyone ever experienced this problem,i've tried every fuse I can find not Knowing EXA-
    -CTLY where the correct one really is,would be grateful if any one could offer
    some useful suggestions/solutions as I've run out of ideas,many thanks.
    gwyntaxi is online now Report Post
    Q
    Report Post
    Q
    Report Post
    Q
    Report Post
    Q
    Report Post
    Q
    Report Post
    Q
    Report Post
    Q
  2. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,575
    2,586
    Trowbridge
    Sonthing wrong with your post I think but bump anyway
  3. gwyntaxi
    gwyntaxi Funster
    Jun 9, 2009
    173
    64
    waunarlwydd,swansea
    SORRY EVERYONE,DON'T KNOW WHY MY PLEA FOR HELP REPEATED ITSELF SO MANY TIMES, I DID TRY COPYING&PASTING IT FROM A DIFFERENT LOCATION SO PERHAPS THAT'S GOT SOMETHING TO DO WITH IT,AND THE FACT THAT I'M USELESS AT ALL THINGS COMPUTING,I'VE TRIED TO ERASE THE EXCESS POSTINGS BUT HAVEN'T GOT A CLUE SO I'LL LEAVE WELL ALONE OR I'LL LOSE THE THREAD ALTOGETHER
  4. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,891
    6,810
    West Sussex
    Hymer's normally use the Schaudt Step Control unit, basically a couple of relay boxes with a current sensor & timer. The ones in our van are EMS 03-3, one will be located near the step in a cupboard or under a draw near the habitation door the other one with either be under the passenger seat (LHD) or near the battery. The one near the battery will have a fuse in-line with it.
  5. gwyntaxi
    gwyntaxi Funster
    Jun 9, 2009
    173
    64
    waunarlwydd,swansea
    Many thanks for the tips lennyhb will try them today and see if I can find these elusive fuses,especiall
    -y the one near the habitacion door.
  6. daveandsan
    daveandsan Funster
    Dec 10, 2013
    1,428
    2,010
    South Staffs
    @Jaws is the expert on electric steps. :rofl:
    • Like it Like it x 1
  7. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,940
    1,959
    Warwickshire
    Just re-reading your original post (post-post-post-post-post-post!) :roflmto: I notice you were trying to find the fuse on the EBL. Given that there appears to be power to the step motor I doubt the EBL fuse has gone, but offer the following in case it helps.
    Not sure what EBL your 655 has, but assuming it's an EBL99 or EBL100, block 4 is the connector for power to the step, heater and frost protection valve.
    The fuse for the step is a 25amp unit in the row of fuses (below the connector blocks). It will be labelled 'Grundlicht / Trittstufe'
  8. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,292
    3,094
    Kendal, Cumbria
    If the step retracted using the switch the fuse is not at fault - it is the same fuse for both directions.
  9. andy63
    andy63 Funster
    Jan 19, 2014
    2,330
    9,040
    south shields
    reading the problem , but not knowing the hymer set up , could it not be the rocker switch its self.. you have power on retract at switch. is it not the same supply to the rocker switch for retract and open, you have voltage on retract but not open, suggesting the switch itself is not working.. may have the wrong end of the stick
    ta andy
  10. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,891
    6,810
    West Sussex
    Hymer use a momentary switch with control boxes. (see my earlier post)
  11. Lindsay
    Lindsay Read Only Funster
    Jun 29, 2014
    16
    10
    Ayton, Scottish Borders
    Hello gwyntaxi,
    Same happened to my step, simple fix was to free off pivot bolts. Try it :)
  12. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,292
    3,094
    Kendal, Cumbria
    My 2005 B584 doesn't. Just a simple polarity-reversing switch.
    • Like it Like it x 2
  13. Granjan
    Granjan Funster
    Aug 4, 2013
    893
    7,485
    Yorkshire
    I am not a techi at all but our step sometimes fails to operate and I am pretty sure that it is just dirt sticking after a road trip i just help it a bit by pushing it as I press the button and then it works and frees off ..... Should probably dismantle something but see this old post
    http://www.The Dark Side/forum-printtopic-1-61403-0-0-asc-viewresult-1.html
    Hope it helps.
  14. Gromett
    Gromett Funster
    Feb 27, 2011
    8,243
    15,343
    UK
    My Hymer had a microswitch to detect when the step was retracted etc. This got clogged up and the step wouldn't work. I gave it a heavy dose of WD40 and clicked it manually a bunch of times.
    This got it working.
  15. andy63
    andy63 Funster
    Jan 19, 2014
    2,330
    9,040
    south shields
    just the op used the term rocker switch which made me think conventional I suppose.. if it was momentary it would only require a push button, or so I thought...
    ta andy
  16. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,891
    6,810
    West Sussex
    It is actually a sprung loaded rocker switch on mine.
  17. gwyntaxi
    gwyntaxi Funster
    Jun 9, 2009
    173
    64
    waunarlwydd,swansea
    Hi everyone,
    I would like to say a big thank you to all of you,for taking the trouble to respond to my request for help,so far I have tried everyone's suggestions',but still no improvement,but I'm gonna keep at it,i've got to,cos the entrance into the van is about 3ft offf the ground,and at the moment I'm using a 3-step stepladder and it ain't doing my hips and knees any good,so thank you all,i@ll keep you posted if and when I get a positive result.gwyntaxi.
  18. gwyntaxi
    gwyntaxi Funster
    Jun 9, 2009
    173
    64
    waunarlwydd,swansea
    Hi Jaws, yes that's the same Electroblock 101 as fitted to mine.
