I Love My E & P Jacks (1 Viewer)
Anthea M
Oct 18, 2015
9,501
165,143
Sheffield
Hobby
Andy.
That looks a great bit of kit and will be a bonus!
Also I :h: How immaculate and tidy your locker space is!!
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Now the milencos have gone my toolboxes reside in their place
Techno
Jul 28, 2010
15,475
20,756
May 2010
Auto is fine as long as you check all four jacks hit the deck
I noticed on very poor ground like where I store it that my front right is a bit light of the floor so I follow up with a manual front
I can't imagine losing the smile factor
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes
Question to new owner, do you prefer auto or manual setting
FYI Mick adjusted the angle of the brain on the under floor to reflect the fact that our van is nose down by default
So we get level in auto baring the final tweek in manual if the ground is very uneven
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Question to owners
Does the novelty ever wear off?
NO. I have both full VB air and the jacks. If a quick stop or on reasonable flat pitch I just level on air. If on a very un-level pitch like here in Barcelona then I put out the jacks and even they may need pads to reduce the stroke. As an aside I think levelling is important to the fridge, so I always level if the fridge is on. I would say we use the jacks 50% of the stops we make. I bought the remote so i can use that to sight up the pad positions.
R
Robert Clark
It's suggested leaving the jacks down when storing as it reduces stress on the tyres.
The only thing I'm concerned about is leaving the handbrake on for long periods, which may cause the pads to stick.
Maybe the trick is to extend the jacks, release the brake, then re apply the brake before turning on the ignition and raising the jacks
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Jacks will lift if handbrake is off I think.
19,485
30,896
Martin @funflair will give the SP
Thanks for the vote of confidence Michael(y) hope I can live up to it.
Should be OK on jacks in storage, but be carefull outside that the extended rams don't get rust on them as they will just be chromed steel.
I don't bother with ours but it never sits for long.
I did leave it 3 weeks with the wheels off a while back and all was fine.
19,485
30,896
And the suspension hanging?
On our IVECO chassis there are stops on the front and rear that take the weight of the hanging suspension so not worried about that.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Spec of new Rams is stainless steel I think it says in the manual
Yes mine is jacked in storage but only to the extent that it is level , the tyres are on the ground but no weight on them
13,129
101,643
Bolsover, Derbyshire
Hymer S800
not long enough
we have had a quite a few attempts to deploy our jacks where they fail, due to 'uneven ground', I don't fully understand that message and the ground is often not that far out of level when we have had issues
It was worrying / annoying early on but I have now found that we can deploy the jacks in manual option and overcome the 'problem', just odd that the auto option wouldn't allow what turns out to be OK o_O
we do love ours though, very easy levelling and totally stable when moving around or when windy, possibly more of an issue with the Mercedes Hymer wheels being quite a long way inset relative to body width
Feb 24, 2013
13,129
101,643
Hymer S800
not long enough
I think I need to relearn the operation of mine
If I use auto, but then want to 'tweak' the settings I thought the legs would retract fully when the 'hand' button is used effectively meaning you then start again
I will go and have a play later (y)
R
Robert Clark
When you get that message David, switch to manual and get the van as level as you can - often virtually level
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
On Robert, they will retract with it off.
Might be an idea to see how many clicks on it takes rather than full lock
Reading through the manual on the website I had the impression that you could release the handbrake once the ignition was off.
Some vehicles have swivel chairs that do not function when the hand brake is engaged. As soon as the levelling system is finished and the ignition switch is off, you are able to disengage the hand- brake. Before doing that, you must of course check if the car is in gear.
Are you saying Andy that this doesn't happen or haven't you tried it yet?
Richard.
Techno
Jul 28, 2010
15,475
20,756
May 2010
I could have sworn that they retracted but I'll check again next time
