Hymer Front End (1 Viewer)
bhs
214
137
Louth
b class
since 2006
Hymer B574 knew about the flat paintwork before I bought the van, am in the process of tidying it up, the front HYMER panel is a bit sad, cracked and crazed,
it has been bedded on a mastic, very thick and crudely applied, are they all like this?
WAG2CRU
376
495
Argyll
Hymer B654SL Star Edition
since2012
No, no mastic on mine, that looks like a bodged repair:eek:
2,347
10,197
Nope.. none on mine either, nor cracks on the Hymer panel..
looks like a bodge :(
bhs
bhs
214
137
Louth
b class
since 2006
so is hymer cut out panel fitted on body dry, with just a screw at each corner? I only came across this anomaly when making room to change the radiator ( and condenser) thanks
bhs
bhs
214
137
Louth
b class
since 2006
Doh!! Will remove the gunge and see what it looks like, I feel the panel is a bit long and flexible for the two small screws in the top to adequately support it, sometimes I do up to 50mph!
19,376
30,367
The front panel will be fibreglass, certainly looks it from the cracks, if you want to tidy this up first you need to make sure there is no structural damage to the back and if ther is it needs backing up with a bit more fibreglass, you then need to dig out the cracks in the Gelcoat with a Dremel or similar and then fill them with Gelcoat. Once they are all filled it can be flatted back and painted.
bhs
bhs
214
137
Louth
b class
since 2006
I think I have the Hymer born to disprove the rule!
bhs
bhs
214
137
Louth
b class
since 2006
Think you are right there, well looked after in this case was a clean loo! Never mind am catching up and like the van despite niggles, its 15 years old so I would probably be changing many of the bits and pieces causing me angst anyway.
2,347
10,197
my apologies .. :whistle:
on closer inspection, mine has a thin layer of what looks like mastic on the top edge..
nothing on the sides or bottom
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
I got a new(ish) front grill panel for our Hymer (Ducato cab) on fleabay......just keep looking, something will appear. It looks like yours might have had a 'push back' at some time.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
But I dont think that this is the same as yours???
bhs
bhs
214
137
Louth
b class
since 2006
Thanks Martin, not sure if I am brave enough to attempt renovation?Maybe a winter project.
Have taken panel (whilst replacing radiators) off, removed all the gungy mastic, and put it back, fingers crossed, have mastic in the back in case the panels vibrate, have visions of a reed effect when driving into the wind, don't want to be mistaken for an ice cream van, fed up with people asking for double cheeseburgers as it is.
PS is the grille/mesh in bottom of front panel fully fitted to the whole it protects? Is that fixed with self tappers on it's top edge only? (mine is)
