Hymer Front End
Discussion in 'Motorhome Chat' started by bhs, May 8, 2015.
  1. bhs
    bhs Read Only Funster
    Apr 16, 2015
    214
    137
    Louth
    Hymer B574 knew about the flat paintwork before I bought the van, am in the process of tidying it up, the front HYMER panel is a bit sad, cracked and crazed, P1030835.JPG it has been bedded on a mastic, very thick and crudely applied, are they all like this?
  2. WAG2CRU
    WAG2CRU Read Only Funster
    May 31, 2012
    378
    496
    Argyll
    No, no mastic on mine, that looks like a bodged repair:eek:
    • Like Like x 1
  3. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,044
    2,917
    Essex
    • Like Like x 1
  4. scotjimland
    Jul 25, 2007
    28,934
    25,589
    Nope.. none on mine either, nor cracks on the Hymer panel..
    looks like a bodge :(
  5. bhs
    Apr 16, 2015
    214
    137
    Louth
    so is hymer cut out panel fitted on body dry, with just a screw at each corner? I only came across this anomaly when making room to change the radiator ( and condenser) thanks
  6. scotjimland
    Jul 25, 2007
    28,934
    25,589
    yes...
  7. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,815
    1,882
    Warwickshire
    I think mine is bonded with some kind of adhesive too.
  8. bhs
    Apr 16, 2015
    214
    137
    Louth
    Doh!! Will remove the gunge and see what it looks like, I feel the panel is a bit long and flexible for the two small screws in the top to adequately support it, sometimes I do up to 50mph!
    • Like Like x 1
  9. funflair
    funflair Funster Life Member
    Dec 11, 2013
    4,902
    5,157
    Guisborough
    The front panel will be fibreglass, certainly looks it from the cracks, if you want to tidy this up first you need to make sure there is no structural damage to the back and if ther is it needs backing up with a bit more fibreglass, you then need to dig out the cracks in the Gelcoat with a Dremel or similar and then fill them with Gelcoat. Once they are all filled it can be flatted back and painted.
    Martin
    • Like Like x 1
  10. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    1,991
    1,434
    Dover
    I thought Hymer parts were hand wraught by Gods from pure unobtainium. Or is that just the price tags.
    • Like Like x 2
  11. bhs
    Apr 16, 2015
    214
    137
    Louth
    I think I have the Hymer born to disprove the rule!
  12. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,953
    2,749
    Englishman in Mid Wales
    Think you'll probly find its the previous owners at fault here:rolleyes: if they are not looked after then any make will end up being sh*te:(
    • Like Like x 1
  13. bhs
    Apr 16, 2015
    214
    137
    Louth
    Think you are right there, well looked after in this case was a clean loo! Never mind am catching up and like the van despite niggles, its 15 years old so I would probably be changing many of the bits and pieces causing me angst anyway.
    • Like Like x 1
  14. scotjimland
    Jul 25, 2007
    28,934
    25,589
    my apologies .. :whistle:
    on closer inspection, mine has a thin layer of what looks like mastic on the top edge..
    nothing on the sides or bottom
  15. Tootles
    Tootles Funster
    Sep 14, 2013
    9,123
    32,113
    Lancaster
    I got a new(ish) front grill panel for our Hymer (Ducato cab) on fleabay......just keep looking, something will appear. It looks like yours might have had a 'push back' at some time.
  16. Tootles
    Tootles Funster
    Sep 14, 2013
    9,123
    32,113
    Lancaster
  17. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,580
    5,644
    West Sussex
    Only if you are silly enough to buy in the UK.:LOL:
  18. bhs
    Apr 16, 2015
    214
    137
    Louth
    Thanks Martin, not sure if I am brave enough to attempt renovation?Maybe a winter project.
    Have taken panel (whilst replacing radiators) off, removed all the gungy mastic, and put it back, fingers crossed, have mastic in the back in case the panels vibrate, have visions of a reed effect when driving into the wind, don't want to be mistaken for an ice cream van, fed up with people asking for double cheeseburgers as it is.
    PS is the grille/mesh in bottom of front panel fully fitted to the whole it protects? Is that fixed with self tappers on it's top edge only? (mine is)
