Help... Wlan link keeps 'dropping' ! (1 Viewer)
2,337
10,145
Anyone internet gurus know why my wireless link keeps 'dropping' ?
I'm using a Hawking dish usb wlan adapter, have spoken to Hawking but with no solution.. worst customer support I've come across..
50% Signal, 90% Link quality .
We are connected to the site wifi so have no access to the router .. sometimes it works for hours without dropping, other times it drops every few minutes .. :Sad:
Rebooting the adapter reconnects it ...
My thoughts are that it drops when inactive.. ie, browsing a page or writing a post.. I've Googled but can't find a definitive answer.. :Sad:
S
sinbad1
You should be ok with 50% signal ad 90% link quality, don't think you have an issue with the Hawkings dish.
Could be lots of things some tings to look at
There are lots of reasons why wifi connections drops. (suspect interference) you would need access to the router to change channels though
firmware on the router may need updating again you would need access to the router.
could also be the routers settings ?
For your end of things
Is the dropping of connection a recent problem? if so you could try a system restore back to when it was working ok.
Make sure there's a tick in internet options/connections to never dial a connection
What is the make of your wireless adaptor? could be you need the latest driver.
You could uninstall the adaptor in the device manager, reboot and let windows reinstall
mobile phones /microwaves etc can also effect your wifi
Regards
2,337
10,145
Regards
Thanks .. this is on the Mac
could be interference, it comes and goes, sometimes ok for hours
As I understood, The Hawking is the wireless adaptor .. the Airport Extreme card is switched off . I might have a word with the owner and get him to change channels .. seems worse during the day ..
Cheers
jim
S
sinbad1
Cheers
jim
Its not uncommon for new units to have their driver out of date, you would need to check with the site for the latest.
Sounds like it is intergerence from other wireless stations though.
Could even be an ISP problem
Sorry no experience of Mac
Regards
43,332
49,500
i had the same proplem a while ago Jim,
i kept loosing the connection on my inbuilt wifi adaptor. (Lappy)
went to the expense of a new router/modem but no difference.
downloaded the updated drivers for the inbuilt wifi adaptor and original router and off we go.
took a while to get used to the updated user console but no more dropped connections:thumb:
2,337
10,145
Hi John
It's a brand new Hawking with the latest driver..
I've had quite a lot of problems with it, the software is at best 'buggy' on the Mac, 26 emails to Hawking tech. support have failed to resolve it..
First of all they said it wasn't compatible with OX 10.5 Leopard so I downgraded the OS to 10.4 Tiger, still no better, they finally admitted it's not as good as it should be .. but dropping the link is a fairly recent occurrence, only in the past few days.
Going to see the site owner about changing the channel.. might help..
cheers
Jim
S
sinbad1
Jim
It may not be your setup thats at fault, sometimes your settings may change thats why i said you could perhaps restore your pc to an earlier time ;but having said that you may not have this option on Mac.
Don't forget that your connection is dependant on the wifi signals transmitted by a router, most of these problems are usually found there, could be the routers firmware /channel settings/other router settings. If the SNR is high then this could cause drop outs.It makes it difficult to resolve this issue as you don't have access to the router configuration.
I had a simular problem with a router it would loose signal every now and again and then reconnect, updated the firmware and was then fine.(my partner who uses a wifi dongle used to curse me when this happened)
My point is Jim if the router is loosing its signal so will you.
it a difficult one to pin down, could be your end or a router problem ;but something has changed, since it did work, could be just a matter of changing the wifi channel?
Regards
2,337
10,145
I think I may have it resolved, I spoke to the owner but he wasn't sure what to do so with his permission I changed the router's ch .. It seems fine now.. just have to wait and see if it's a permanent fix..
thanks for advice
Jim
S
sinbad1
thanks for advice
Jim
Fingers crossed:thumb:
