Help... Wlan link keeps 'dropping' !
Discussion in 'Web Connections' started by scotjimland, Apr 24, 2009.
  1. scotjimland
    Jul 25, 2007
    28,935
    25,616
    Anyone internet gurus know why my wireless link keeps 'dropping' ?
    I'm using a Hawking dish usb wlan adapter, have spoken to Hawking but with no solution.. worst customer support I've come across..
    50% Signal, 90% Link quality .
    We are connected to the site wifi so have no access to the router .. sometimes it works for hours without dropping, other times it drops every few minutes .. :Sad:
    Rebooting the adapter reconnects it ...
    My thoughts are that it drops when inactive.. ie, browsing a page or writing a post.. I've Googled but can't find a definitive answer.. :Sad:
  2. sinbad1
    sinbad1 Deleted User
    You should be ok with 50% signal ad 90% link quality, don't think you have an issue with the Hawkings dish.
    Could be lots of things some tings to look at
    There are lots of reasons why wifi connections drops. (suspect interference) you would need access to the router to change channels though
    firmware on the router may need updating again you would need access to the router.
    could also be the routers settings ?
    For your end of things
    Is the dropping of connection a recent problem? if so you could try a system restore back to when it was working ok.
    Make sure there's a tick in internet options/connections to never dial a connection
    What is the make of your wireless adaptor? could be you need the latest driver.
    You could uninstall the adaptor in the device manager, reboot and let windows reinstall
    mobile phones /microwaves etc can also effect your wifi
    Regards
  3. scotjimland
    Jul 25, 2007
    28,935
    25,616
    Thanks .. this is on the Mac
    could be interference, it comes and goes, sometimes ok for hours
    As I understood, The Hawking is the wireless adaptor .. the Airport Extreme card is switched off . I might have a word with the owner and get him to change channels .. seems worse during the day ..
    jim
  4. sinbad1
    Its not uncommon for new units to have their driver out of date, you would need to check with the site for the latest.
    Sounds like it is intergerence from other wireless stations though.
    Could even be an ISP problem
    Sorry no experience of Mac
    Regards
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,958
    17,634
    YO11 2BD
    i had the same proplem a while ago Jim,
    i kept loosing the connection on my inbuilt wifi adaptor. (Lappy)
    went to the expense of a new router/modem but no difference.
    downloaded the updated drivers for the inbuilt wifi adaptor and original router and off we go.
    took a while to get used to the updated user console but no more dropped connections:thumb:
  6. scotjimland
    Jul 25, 2007
    28,935
    25,616
    Hi John
    It's a brand new Hawking with the latest driver..
    I've had quite a lot of problems with it, the software is at best 'buggy' on the Mac, 26 emails to Hawking tech. support have failed to resolve it..
    First of all they said it wasn't compatible with OX 10.5 Leopard so I downgraded the OS to 10.4 Tiger, still no better, they finally admitted it's not as good as it should be .. but dropping the link is a fairly recent occurrence, only in the past few days.
    Going to see the site owner about changing the channel.. might help..
    cheers
    Jim
  7. sinbad1
    Jim
    It may not be your setup thats at fault, sometimes your settings may change thats why i said you could perhaps restore your pc to an earlier time ;but having said that you may not have this option on Mac.
    Don't forget that your connection is dependant on the wifi signals transmitted by a router, most of these problems are usually found there, could be the routers firmware /channel settings/other router settings. If the SNR is high then this could cause drop outs.It makes it difficult to resolve this issue as you don't have access to the router configuration.
    I had a simular problem with a router it would loose signal every now and again and then reconnect, updated the firmware and was then fine.(my partner who uses a wifi dongle used to curse me when this happened)
    My point is Jim if the router is loosing its signal so will you.
    it a difficult one to pin down, could be your end or a router problem ;but something has changed, since it did work, could be just a matter of changing the wifi channel?
    Regards
  8. scotjimland
    Jul 25, 2007
    28,935
    25,616
    I think I may have it resolved, I spoke to the owner but he wasn't sure what to do so with his permission I changed the router's ch .. It seems fine now.. just have to wait and see if it's a permanent fix..
    thanks for advice
    Jim
  9. sinbad1
    Fingers crossed:thumb:
