Help urgent. (1 Viewer)
movan
21,492
120,753
Moving around
Burstner
since07
Gone to storage unit and loaded van wTer etc etc ... switched fridge on .. Nothing. Tried it on gas ... nothing.
I was just about to set off for New Forest meet .. can't go if dont get this sorted as fridge will be needed over next few months ... long story ...
Any suggestions what i can rry to get it working please as it was working when I left it. Thank you.
Zigisla
2,581
3,107
Gosport, Hants
Sunlight A72
Hab 12 v switched on? Start Engine and see if that kicks in on 12 v just to check if fridge will work on anything.
Scout
3,960
122,030
South Yorkshire
chic c line
yes Joy, but have you turned on your 12volt, its needs that to work on anything,
Will it work on mains?
when did it last work.....
cliffanger
4,861
34,105
Saltford
Hymer A class
Colin has said is the van completely level? You might think it is but if it's A little bit out this may stop it working.
Feb 17, 2009
359
1,377
Cheltenham
AS Broadway FB
Can't help with the fridge but if you're passing Cheltenham I've got a 12volt cool box you could borrow.
movan
movan
21,492
120,753
Moving around
Burstner
since07
It last worked at Malvern caravan meet.
Do you think a fuse could stop it working. I have switched engine on and it not work on 230v. I never seitch my 12v off.
Zigisla
2,581
3,107
Gosport, Hants
Sunlight A72
If all fuses etc. are OK, then you have reached the end of my knowledge. I have checked my handbook, all be it a Thetford, and it only mentions 12 v Hab supply, 12 v From engine and the fuses. All power sources need 12 v, so a fuse check need to be done. Check if another circuit uses the same fuse and see if that is working.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Will the fuse that feeds the 12v be the one in the protected engi e fuse box or amongst the million others under seats and in cupboards please?
cliffanger
4,861
34,105
Saltford
Hymer A class
Joy have just PMd you Popeye's number - Colin is here and awaiting your call....
Scout
3,960
122,030
South Yorkshire
chic c line
when was that how long ago ?
firstly are other 12volt things working?
Zigisla
2,581
3,107
Gosport, Hants
Sunlight A72
If nothing is working, then it may well be the fuse to the hab area, but I don't know where that would be. That a task for your handbook. Could the 12 V switch have been accidentally switched off / knocked or something? Do you have anything that works without hab power i.e. electric step or external light?
Why is everyone saying fuse ? The Electroblok controller turns 12V off if the leisure battery drops too low, you then have to charge a bit and press 12V ON.
Scout
3,960
122,030
South Yorkshire
chic c line
this sound most liky, get it on mains and put some charge into the battery, then make sure your your 12 volt is on.
Yes there will be a main fuse but why would that blow in storage ?
Yes there is a low voltage trip - why would that trip in storage - because the leisure battery discharged. There are a dozen reasons why the leisure battery would discharge.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Hi all .. no the light doesn't come on .. NOTHING is working on 12v ... lights .. pump ..
The battery isn't flat because it reads 13v.
I dont have a 12v on off switch on my panel and never used one. Am trying to contact @GJH desperately ss he has same van to ask if there a 12v on off switch I don't know about. Prob now my wifi and fone going to run out of charge.
Colin has said if I can get to them tomorrow they will look at it. It means lay
movan
movan
21,492
120,753
Moving around
Burstner
since07
I don't think the 12v discharged .. it reading over 13.
Spoke to Gjh .. he has same system BUT he has a switch at side. I don't and there doesn't appear to be one in the manual either
Zigisla
2,581
3,107
Gosport, Hants
Sunlight A72
Drive to forest meet and set a challenge.
First one to get fridge working gets.....you can add the rest. (y);)
