Hard Water in Spain... (3 Viewers)
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Having lived a couple of times in Spain for many years..
I dont remember the water back in the early 1980`s being as hard as it is...
We have been at Zahora for just over 5 weeks and we have had to descale the kettle a couple of times...
Noticing that we have unpacked our "Britas Filter Jug"... and that has cured the problem..
I know you can buy large bottles of water but I think a Britas and a couple of filters in with your gear is more financial benefit.. (Just our oppinion)..
We use the site Hot Water for dishes and showers... (We have paid for it so why not :Cool: )...
Just bought this to your attention... thinking of the inside of your RV.. or MH.. "Boiler"...:whatthe:
No need to thank me, just buy me a drink at "Marjal"... :Tongue1::thanks2::ROFLMAO:
beachcaster
3,044
3,161
east sussex
a few years
:whatthe:
Hope you are enjoying the sunshine down there:)
our water is very hard......every time I turn the tap on I hear
"who you looking at pal ?"
barry:Smile:
JJ
Mágica
May 1, 2008
19,259
48,056
Burstner Privilege T
over 50 years
Exactly Barry...
Hey Mo... if that Spanish water is giving it "large" just say...
"Armada, 1588" and that should sort it out...
JJ :Cool:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
If you are using Spanish water and using the on-board boiler make sure your sacrificial rod is not deteriorated otherwise the boiler will not be long before its not a boiler anymore.......Its just another water tank.
Douglas
2,835
400
South Wales,
My thoughts also.
Not that I am recommending this; but when we lived on boats there was problem of calcium deposits building up in the toilet pumping system, the cure was to put a little "Agua forte" Hydrochloric acid into the toilet and pump it around then leave for a few hours.
Doug...
Feb 22, 2008
12,266
45,062
Nearly Tugging
Our water is really hard here in fact last week the dogs walked on it :winky:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Spanish water is well known for its high calc content. It will totally destroy a MH boiler in a very sort time if the sacrificial rod is not intact. I always run my boiler at the minimum setting to try to combat this but if your boiler is not adjustable as some are then the only line of defence is the sacrificial rod.
Welsh girl
3,658
3,036
Globecar
Whats a sacrificial rod when its at home?
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Mo the OP has an American RV, all RVs have what I think is technically called an anode rod in the boiler,which collects calk and is slowly eaten away as a sacrifice instead of the boiler being eaten away. Not knowing as much about European MHs I presume they have something similar. If not and the water being used through the hot system is hard then the best way to combat the build up of the calk is to not have the boiler running hotter than is absolutely required.
Just something else to worry about :winky:
Welsh girl
3,658
3,036
Globecar
Thank the lord for that I thought it meant a stick someone tied the lamb to :):):)
old-mo
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
We have not used the boiler for that reason.. "Furring Up"....
I dont think we have a temperature setting on ours... Never found one anyway..
It`s either on with Gas or Electric or off.. Unless there is a temp setting thingy I have not found ..
Where am I likely to find it ???? :thumb:
Thanks Snowbird.. :thumb:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Try taking the drain tap out of the boiler and the anode should be attached to the back of the drain tap. If you have a water temp adjustment it will be adjoining the boiler switch. I think you can adjust the boiler cutoff on the boiler manually but have given all my repair manuals away with the RV. Sorry cant be of much more help Mo.
old-mo
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Thanks Snowbird...... I`ll have a look when I get home... as said not using the boiler...:thumb:
And the way my luck has been if I try pulling things to bits out here I will *ock things up..:Doh:
