Hard Water in Spain...
Discussion in 'Continental Touring' started by old-mo, Dec 26, 2011.
  1. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    13,022
    40,318
    Having lived a couple of times in Spain for many years..
    I dont remember the water back in the early 1980`s being as hard as it is...
    We have been at Zahora for just over 5 weeks and we have had to descale the kettle a couple of times...
    Noticing that we have unpacked our "Britas Filter Jug"... and that has cured the problem..
    I know you can buy large bottles of water but I think a Britas and a couple of filters in with your gear is more financial benefit.. (Just our oppinion)..
    We use the site Hot Water for dishes and showers... (We have paid for it so why not :Cool: )...
    Just bought this to your attention... thinking of the inside of your RV.. or MH.. "Boiler"...:Eek!:
    No need to thank me, just buy me a drink at "Marjal"... :Tongue1::thanks2::Rofl1:
  2. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    Hope you are enjoying the sunshine down there:)
    our water is very hard......every time I turn the tap on I hear
    "who you looking at pal ?"
    barry:Smile:
    • Like it Like it x 2
  3. JJ
    JJ Funster
    May 1, 2008
    15,114
    27,218
    Exactly Barry...
    Hey Mo... if that Spanish water is giving it "large" just say...
    "Armada, 1588" and that should sort it out...
    JJ :Cool:
  4. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,336
    17,057
    Liverpool.
    If you are using Spanish water and using the on-board boiler make sure your sacrificial rod is not deteriorated otherwise the boiler will not be long before its not a boiler anymore.......Its just another water tank.
  5. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    My thoughts also.
    Not that I am recommending this; but when we lived on boats there was problem of calcium deposits building up in the toilet pumping system, the cure was to put a little "Agua forte" Hydrochloric acid into the toilet and pump it around then leave for a few hours.
    Doug...
  6. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    9,064
    14,369
    Norfolk
    Our water is really hard here in fact last week the dogs walked on it :Wink:
  7. Snowbird
    Apr 24, 2009
    10,336
    17,057
    Liverpool.
    Spanish water is well known for its high calc content. It will totally destroy a MH boiler in a very sort time if the sacrificial rod is not intact. I always run my boiler at the minimum setting to try to combat this but if your boiler is not adjustable as some are then the only line of defence is the sacrificial rod.
  8. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,839
    1,398
    living the dream.
    Whats a sacrificial rod when its at home?
  9. Snowbird
    Apr 24, 2009
    10,336
    17,057
    Liverpool.
    Mo the OP has an American RV, all RVs have what I think is technically called an anode rod in the boiler,which collects calk and is slowly eaten away as a sacrifice instead of the boiler being eaten away. Not knowing as much about European MHs I presume they have something similar. If not and the water being used through the hot system is hard then the best way to combat the build up of the calk is to not have the boiler running hotter than is absolutely required.
    Just something else to worry about :Wink:
    • Like it Like it x 1
  10. Welsh girl
    Nov 7, 2009
    2,839
    1,398
    living the dream.
    Thank the lord for that I thought it meant a stick someone tied the lamb to :):):)
  11. old-mo
    Oct 16, 2008
    13,022
    40,318
    We have not used the boiler for that reason.. "Furring Up"....
    I dont think we have a temperature setting on ours... Never found one anyway..
    It`s either on with Gas or Electric or off.. Unless there is a temp setting thingy I have not found ..
    Where am I likely to find it ???? :thumb:
    Thanks Snowbird.. :thumb:
  12. Snowbird
    Apr 24, 2009
    10,336
    17,057
    Liverpool.
    Try taking the drain tap out of the boiler and the anode should be attached to the back of the drain tap. If you have a water temp adjustment it will be adjoining the boiler switch. I think you can adjust the boiler cutoff on the boiler manually but have given all my repair manuals away with the RV. Sorry cant be of much more help Mo.
  13. old-mo
    Oct 16, 2008
    13,022
    40,318
    Thanks Snowbird...... I`ll have a look when I get home... as said not using the boiler...:thumb:
    And the way my luck has been if I try pulling things to bits out here I will *ock things up..:Doh:
