I've just had a punt at these, I'll let you know
Broken Link Removed
How did you rate these ?
I have them saved in my watch list at the mo, appreciate your feedback :thumb:
Broken Link Removed
Thanks again. Are the ali brackets you use better than the plastic ones that most sell?
No better or worse but I make my own. However I moved on and now mount them toe in and use a pan head screw upwards through the base to ensure the minimum adhesive thickness
Broken Link Removed
I pay £2 each delivered.
Just deburr and drill
Answers tonight
I'm working on my van once this cafe gives me breakfast
Broken Link Removed
Neat job.
Would you use the same method on a steel panel van roof, or something different?
For 35mm frames I use 2.5"x1.5" 165mm longWhat size are they please and where do you get them from? Most stockists only seem to supply up to 50x50 ali angle. What is the minimum adhesive thickness recommended please and which Sika product to you? Sorry for all the questions.
That's fine thanks. Using these brackets toe in would give me more room between my rooflights so I may be able to fit in one large 200W panel rather than two smaller 100W. Is there any disadvantage with having one large rather then two small, because the wiring would be easier.
i have just bought 2 solar panels 1 regulator and 2kw inverter £780 and the panels have a25 year warranty they are great marjohn:thumb:I'm struggling to find good solar panels just now.
I just bought by ebay auction from Ecoworthy and it is crap and I suspect a number of seller names are the same Chinese people selling the same crap. Great propaganda about quality control etc on their selling pages but not followed up by the product oh:
In the past I've had real quality for good prices but they seem to be missing now :Sad:
Techno, sorry for another question. Is the ali angle you use anodised as it seems to have a shiny finish?
what about these . my mate bob as got some and they seem to work fine on his truck .
Broken Link Removed
some of the smaller ones are cheap as well.
Broken Link Removed
these seem very cheap.
Broken Link Removed
Broken Link Removed
@Techno Have you found anywhere better to buy panels than here?
http://www.ebay.co.uk/sch/m.html?_odkw=&rmvSB=true&_ssn=bau-tech2012&item=261468417553&afsrc=1&clk_rvr_id=1046028936245&_osacat=0&ssPageName=STRK:MEBIDX:IT&_from=R40&_trksid=p2046732.m570.l1313.TR0.TRC0.H0.X100+watt+monocrystalline+12+volt+solar+panels.TRS0&_nkw=100+watt+monocrystalline+12+volt+solar+panels&_sacat=0
Presumably they work fine with your preferred MPPT controller?
Probably got polarity wrong somewhere. Its easy to get confused with MC4 connectors. Disconnect at the regulator and check it there
