Good solar supplier (1 Viewer)
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
What do I need to look out for regarding controllers, most seem to be 10A, what is recommended, what are MPPT controllers?
Techno
Techno
Jul 28, 2010
15,475
20,752
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Not solar panels Andy, but I had the very same issue with the Ebay resolution centre, who advised me that on this occasion, they would refund me in full, but would refuse to do so again under the same circumstances, and put a mark against my account to that effect. :whatthe:
There are so many foreign traders on Ebay, portraying themselves as UK traders. :Angry:
Cheers,
Jock.
Not the case with me Jock
This is what they said
We've decided to issue you a courtesy refund for this case on 22 Mar, 2014 to the PayPal account you used to purchase this item. The refund includes the purchase price plus original postage & packaging. Please log into PayPal to get your refund.
AND
Andrew, please be assured that your case has been taken care of and I determined that you do not have to returned the item. Since the location of the item in the listing is United Kingdom but the seller’s return address is in Hongkong. As a courtesy, we would like to take care of this today by issuing you a full refund (for the cost of the item plus shipping). You'll also receive a follow up email about our decision, along with the item and case details for reference.
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
Andy, If you navigate Bimbles site, you do not have to buy a complete kit.
I added all my ingredients individually (I actually needed the full Monty apart from a battery) and got a 165W Monocrystaline (by Isofoton, a Spanish company that went bust, using USA components) panel, it has a treated surface to work better should it be cloudy. I am no expert but seems pretty solid and looking at others on Sunstore etc, very similar ! a 20A MPPT controller, with the add on Meter, 12 metres of 6mm solar cable, a pair of Mc 4 connecters, a 7 piece plastic mounting kit. All for less than £250:Smile:
I just needed 2 tubes of Sikkaflex 512 and a can of activator. You talked me into ! I did bolt it down but that was a condition forced onto me because of the roof construction of my van. It ain't going anywhere in a hurry except where I take the van. :roflmto:
DavidN
Surrey
Just looking
Newbie
I fitted a Chinese 100W panel and MPPT controller to my live-aboard canal boat four years ago. I got them from Midsummer Energy. The kit has performed faultlessly and I would have no hesitation in buying from Midsummer again.
David.
Techno
Techno
Jul 28, 2010
15,475
20,752
May 2010
Cheers but I've bought from Germany already should arrive next week. I've had panels shipped before and had problems too but always resolved with German sellers. they will collect at their expense if damaged/broken or other complaints.
Dec 5, 2013
317
249
Somerset
Newbie
All from Bimbles?
Moodybrook when you say you bought your components individually
do you mean from different suppliers or as individual components from Bimbles?
The reason I ask is, I am local to Bimbles & if they are good quality I will buy direct from them.
Moodybrook
802
651
still in nappies
I got all the kit from Bimbles apart from the Sikkaflex . What I meant was that I made up my kit by selecting the items to customise my requirements. I had a few queries about various things and I found them prompt and concise with their replies. You will save the delivery costs lucky sod ! :roflmto:
Moodybrook
802
651
still in nappies
Bimble
Watch the size of the 165W panel it is a big one.
317
249
Somerset
Newbie
Moodybrook thanks
Moodybrook thanks for letting me know, I guess I will measure up on the MH roof & start planning.
Moodybrook
802
651
still in nappies
Solar Panel
Broken Link Removed
That is what I ended up with.
Moodybrook
802
651
still in nappies
More phots of what I did
Broken Link Removed
To Explain.
The 20A MPPT controller, I have also added to the controller a Meter which tells me what is going on (in a fashion). The extra battery added (under the yellow cover, I have two matched 110 AHC supposedly deep cycle babies, time will tell !). Two thick cables joining up that battery with the existing one in Parallel. To the left of the Controller is a 20A mcb circuit breaker instead of a fuse and that cable from the controller goes to charge up the Leisure batts. The red 10mm cable that disappears off to the left is the cable that connects to my vehicle battery to let the Solar, or the EHU, charge up my Vehicle battery, in essence making the two Leisure batts and the Veh batt one big batt. Near the Vehicle battery is another 12V 20A mcb circuit breaker in case I forget to open/break the circuit to the Leisure Batteries and I wind up the engine. I am led to believe that when you start up the engine all sorts of hell lets loose blowing batteries and wrecking the economy of the world. So the MCB(It could be a sacrificial fuse) should save the planet ?? I went with MCB's as I thought they would be easy to spot that something cataclysmic had happened and if I sussed it out, they are easy to reset, press button.
Techno
Techno
Jul 28, 2010
15,475
20,752
May 2010
German ebay solars just arrived and very well packaged. final delivery by DPD on this side.
I'll unpack and give a verdict
Broken Link Removed
Nov 18, 2011
11,857
42,489
Planet Earth
A van
Over 25 year's
I have a solar panel company near me and was thinking of just fitting one of there units to the roof of my van can it be done ?
Techno
Techno
Jul 28, 2010
15,475
20,752
May 2010
Both panels have damage so back to the drawing board! ebay resolution again :Doh:
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
Jeeze Andy, you're going to loose all your hair at this rate - are they that much cheaper than the ones from Sunstore etc? (Based in UK).
The quality of theirs is superb - not too sure if they are that much more expensive than the ones from ebay.
There was something in the news last night that mentioned UK is now the 'official dumping ground' for Chinese solar panels.
:Angry:
Regards,
Trikeman. :winky:
Techno
Techno
Jul 28, 2010
15,475
20,752
May 2010
Broken Link Removed
Broken Link Removed
Broken Link Removed
Broken Link Removed
JockandRita
11,402
148,470
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Are these the ones you get from Germany? :whatthe:
I couldn't be doing with all the hassle Andy. :cry:
I hope you manage to get it all resolved to your satisfaction.
Cheers,
Jock.
Jaws
23,821
71,977
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
They do look good Martin but I notice both 80 & 100 are out of stock.
However Addie has sent me a link to some from Germany and they do look excellent. So next time I'm home for a week I'll have some delivered.
I have had a few from Germany.. always top notch !
Jaws
23,821
71,977
Thetford Norfolk
C class, Chieftain
Bugger.. bet they were not MADE in Germany then ....
Jul 23, 2013
381
221
Scotland
knaus van ti 600mg
Getting There since 2013
The packaging looks a bit flimsy, you'd think it would be in a stronger cardboard box?
Did you say earlier that this company "any problems we'll collect and pay all the costs" hopefully they stick to it :winky:
Techno
Techno
Jul 28, 2010
15,475
20,752
May 2010
No I said German sellers I've used in the past. I will have to wait and see how this one deals with it.
Techno
Techno
Jul 28, 2010
15,475
20,752
May 2010
Seller has requested photos to their email address and now confirmed receipt and that they are contacting the couriers
Techno
Techno
Jul 28, 2010
15,475
20,752
May 2010
Latest info is they are still negotiating with DPD but I think they're sending me replacements. I have asked that they protect the corners better.
Techno
Techno
Jul 28, 2010
15,475
20,752
May 2010
Update
They lead me to believe that a replacement was dispatched on the 2nd of April, by the 8th I felt they should be here so I asked again? they said yes we sent out some more. I then asked for the tracking number.
This morning they sent the tracking number and surprise! only posted yesterday the 10th
German efficiency :ROFLMAO: NOT
Tmesis
29
10
Surrey
4 years
Can you post their contact details please? I'm looking for a pair of 100w mono panels and the supplier I previously used doesn't have any.
Techno
Techno
Jul 28, 2010
15,475
20,752
May 2010
The replacement panels just arrived and mercifully not damaged this time.
I bought from here on "Addie"'s recommendation and I will put them in grade A with the reservation that the connecting tails are only 2.5mm.
Since buying the price has gone UP massively, this may be the seasonal effect.
http://www.ebay.co.uk/itm/350726354084?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
I wont be buying more from here as it is too drawn out and stressful :roflmto:
No mention has been made about recovering the damaged panels
Panel label
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I wonder whether this might be a copycat brand panel? The label says Solartronics LEIPIG - Germany. Having searched for Solartronics, they are based at LEIPZIG. I would have thought it unlikely that such a well-known city would have been misspelled?
Here are their contact details:
solartronics, Inhaber Jörg Windolf
Angerstrasse 40-42
04177 Leipzig
per Fax: +49 (0)341 - 870 8599 4
oder per E-Mail: vertrieb@solar-tronics.de
