gas take off point (2 Viewers)
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
I want to add a gas outlet to run a cadak from don't want to drill bodywork but looking in the gas locker can I take a feed direct from the truma auto change over valve. It has a capping nut on the outlet(probably for test gear to connect to) with that removed could I connect into that?
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I think the connection on the Truma valve is, as you say, for a pressure test unit. I would have thought this is not something to connect an offtake into. Should be easy to fit a take-off point but you will need to do a bit of cutting into the existing gas pipe. I had a Bullfinch point fitted but wanted it mounted through the van wall. The feed for that came from the pipe feeding the Truma heater under the wardrobe.
Aug 17, 2011
422
211
North East
Dethleffs T7057
We had one fitted into our locker instead of cutting a hole in the outside. Only used it twice so far but worked well!! The pipe into the van was cut and a joint added in with the point on!
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Cut a hole Mick! mine is in the skirt (not fitted by me) easy to pipe up under the van.
Techno
Jul 28, 2010
15,475
20,756
May 2010
I replaced all the pipework myself as the professional made a right crock of it all (under previous owner)
aba
2,775
1,112
yorkshire
dec 2009
thanks for photo my van is very similar gives me an idea probably get to gas pipe inside fridge vent:thumb::thumb:
Never thought of that one:Doh:
Just tee off the fridge supply and when you want to use it remove the fridge vent.
On second thoughts a hole in the skirt is probably the best way to go.
Or maybe the easiest is just drag the spare calor bottle out of the locker.
Jan 28, 2008
10,121
18,390
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
as an alternative to the bulfinch you could tee in to a suitable gas pipe and mount one of these Broken Link Removed somewhere
32,673
66,650
Techno ... have you used your new 'toy' yet? ::bigsmile:
mentaliss
654
306
Lancing
like this one:Smile:
Clive
1,296
1,782
Canvey Island
I have both the BBQ point and my gas filler point in the skirt right next to the gas locker, simples ::bigsmile:
