gas take off point
Discussion in 'Tech/Mech General' started by mick noe, May 13, 2014.
  1. mick noe
    mick noe Funster
    Apr 14, 2009
    615
    522
    near Boston Lincolnshire
    I want to add a gas outlet to run a cadak from don't want to drill bodywork but looking in the gas locker can I take a feed direct from the truma auto change over valve. It has a capping nut on the outlet(probably for test gear to connect to) with that removed could I connect into that?
  2. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,849
    1,907
    Warwickshire
    I think the connection on the Truma valve is, as you say, for a pressure test unit. I would have thought this is not something to connect an offtake into. Should be easy to fit a take-off point but you will need to do a bit of cutting into the existing gas pipe. I had a Bullfinch point fitted but wanted it mounted through the van wall. The feed for that came from the pipe feeding the Truma heater under the wardrobe.
    • Like Like x 1
  3. Stacetop
    Stacetop Funster
    Aug 17, 2011
    173
    69
    We had one fitted into our locker instead of cutting a hole in the outside. Only used it twice so far but worked well!! The pipe into the van was cut and a joint added in with the point on!
    • Like Like x 1
  4. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,135
    15,070
    Leeds the one up North
    Cut a hole Mick! mine is in the skirt (not fitted by me) easy to pipe up under the van.
    [​IMG]
    • Like Like x 1
  5. mick noe
    mick noe Funster
    Apr 14, 2009
    615
    522
    thanks for photo my van is very similar gives me an idea probably get to gas pipe inside fridge vent:thumb::thumb:
  6. Techno
    Jul 28, 2010
    14,135
    15,070
    I replaced all the pipework myself as the professional made a right crock of it all (under previous owner)
    [​IMG]
  7. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    Never thought of that one:Doh:
    Just tee off the fridge supply and when you want to use it remove the fridge vent.
    On second thoughts a hole in the skirt is probably the best way to go.
    Or maybe the easiest is just drag the spare calor bottle out of the locker.
    • Like Like x 1
  8. grasscutter
    grasscutter Funster Life Member
    Oct 11, 2009
    1,369
    2,277
    East Wittering. West Sussex.
    I did as others have suggested and cut a T piece into the fridge supply and then fitted a bullfinch point into the skirt. :thumb:
    • Like Like x 1
  9. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,116
    3,524
    walthamstow east london
    • Like Like x 1
  10. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,835
    11,307
    E Yorks
    Techno ... have you used your new 'toy' yet? :BigGrin:
  11. Techno
    Jul 28, 2010
    14,135
    15,070
    No :RollEyes:
    [​IMG]
  12. mentaliss
    mentaliss
    Nov 2, 2012
    657
    307
    Lancing
    like this one:Smile:
    • Like Like x 1
  13. Clive
    Clive Funster Life Member
    Apr 30, 2012
    768
    1,183
    Canvey Island
    I have both the BBQ point and my gas filler point in the skirt right next to the gas locker, simples :BigGrin:
    • Like Like x 1
