Gas powered generators (3 Viewers)
Feb 24, 2013
13,087
101,468
Bolsover, Derbyshire
Hymer S800
not long enough
Hello
I have seen an advert for a gas powered generator fitted to motorhomes, not asked about spec yet or prices, does anybody have any experience?
Do they literally run off the LPG bottles. or am I missing something?
I have tried to search through old threads but cant see anything recent, my apologies if I am repeating things here
43,332
49,502
bottle or fixed tank depending on regulator and calorifier/vapouriser.
Many suitcase generators (Honda, Kipor etc) run from a bottle and use gas vapour.
Fixed generators usually run off a fixed tank and use liquid gas
DavidG58
Feb 24, 2013
13,087
101,468
Hymer S800
not long enough
I am considering having one fixed (in an outside locker I presume) on my MH. will it need its own gas tank? gets a bit messy if it does
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
No reason why you should not pipe to the genny from your bottles if you want to.
Do bear in mind that while some manufacturers actually produce and sell gas conversions for their generators once a gas conversion is fitted it nullifies the warranty - that is quite some consideration with Honda which is a 5 year warranty.
DavidG58
Feb 24, 2013
13,087
101,468
Hymer S800
not long enough
This is a link to the advert for Hambilton Engineering, I am booked in with them for a habitation service next week and am going to ask them for details and a price to fit their refillable gas cylinders and the generator shown (Electrolux)
I might be scared off by price yet, but this package seems to answer all my needs for varied use (on / off sites)
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Electrolux prices appear to be higher than Conrad - Andersons + fitting - start at £2700 and reach the giddy heights of £7100 for the top of the range one :Eeek: makes a Honda suitcase 2.0i cheap at around £1400 with a 5 year warranty
DavidG58
Feb 24, 2013
13,087
101,468
Hymer S800
not long enough
Maybe a tad higher than I had expected or am prepared to pay, I already have a suitcase genny, does a great job, trying to tidy up the garage though and move some weight around
many thanks, a non starter I now think
43,332
49,502
sorry, i thought you meant a normal 240v generator.
You could get your suitcase generator gas converted to run off bottles for around £100
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Hello
It depends, a small LPG generator can run off standard bottles, at least in warmish weather. Larger ones will need more gas than a bottle can vaporise, so will typically require a liquid feed which is will then vaporise itself. This can't be run off the same pipework as the fridge/cooker, as the outlet needs to be at the bottom of the tank, not the top.
43,332
49,502
which of course is why a large engine LPG conversion uses liquid gas taken from the bottom of the tank. :thumb:
DavidG58
Feb 24, 2013
13,087
101,468
Hymer S800
not long enough
I thought there must be a good reason why we did not all have one
Now see price will stop most of us, then it does not sound practical for standard sized MH's
Thanks for the info
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Thanks for the info
It would be easy enough on mine, as it has an LPG engine, so already has a large tank with liquid take off. However, we have low electricity usage, so the solar seems more than enough. The only thing to tempt me would be to put in a really big one that could run the air conditioning.
2,337
10,146
It depends,[HI] a small LPG generator can run off standard bottles, at least in warmish weather.[/HI] Larger ones will need more gas than a bottle can vaporise, so will typically require a liquid feed which is will then vaporise itself. This can't be run off the same pipework as the fridge/cooker, as the [HI]outlet needs to be at the bottom of the tank, not the top.[/HI]
Correct.. it all depends what you call 'small'..
for example.. I had a 4kw LPG genny on our RV that run off vapour..
It had it's own vapour line with the regulator near the tank..
Liquid tapping points on LPG tanks are usually on top of the tank and have a liquid syphon tube If tapped from the bottom they can pick up rust and dirt.
It's not possible to identify whether its a liquid or vapour take off point just by looking at it.
