Gas Hose identifcation (1 Viewer)
Jan 2, 2015
2,472
8,629
Cumbria
Burstner Solano t725
since 2014
I picked up this hose in a job lot of other LPG fittings recently and would appreciate some assistance in identifying its use. It is about 5 metres long and has what looks like a POL fitting on one end.
The script on the hose is (i think) italian. Due to its length I would guess maybe a BBQ hose or similar.
Any ideas?
wasp
1,724
18,180
Warsop
None gone caravannin
You are probably right or it could be a blowtorch lead, is there a date on it I think the recommended usage date is 5years so if you are thinking of using it just check the ingrity of the rubber, if it ha any cracks or perish marks bin it
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
I concur with both suggestions perhaps BUT
I am alarmed to see what looks like a direct cylinder connector on one end:rolleyes:
That would seem to enable a very Dangerous direct connection to a cylinder without using a pressure regulator:eek:
I would pass on its previous use and cut that big fitting OFF for sure(y)
G
Jun 29, 2015
3,477
57,425
Southampton
caravan (for now)
on and off since 1984
It is a high pressure hose and must go to a regulator. Do not use it for anything else, unless you take the end off first. Also as previous reply check the date, if over 5 years bin it
wasp
1,724
18,180
Warsop
If it is a European lead the regulator fits on the appliance it is a strange set up the French used to be notorious for it
scotjimland
2,327
10,081
A Woosh bang
I was just about to suggest that.. I've also seen American gas barbies with built in regulators..
wasp
1,724
18,180
Warsop
See great minds think alike I wasn't aware of the American Barbys
namwaldog
Jan 2, 2015
2,472
8,629
Cumbria
since 2014
Thanks for all your replies. Both ends now cut off and the remaining length of 8mm hose (dated 2016) will be kept as possible spare hose as it is in very good condition
