Gas hob going out (1 Viewer)
deanroofing
297
253
bedfordshire
since 2010
Hi Guys,
Got a problem with my gas hob, keeps going out on its own, it's a Thetford Spinflo, on a Gaslow system our blown gas which is a Truma Combi is working fine, any ideas or solutions would be gratefully received.
Thanks in advance.
17,635
43,360
sounds like the flame failure device cutting it off if the pressure is ok. This relies on a thermocouple that gets heated by the gas flame to keep the valve open. If for whatever reason the thermocouple is not being kept hot, the gas will shut off
check that the thermocouple has not been dislodged when cleaning the hob and that you havent got a draft across it from an open window
wasp
1,724
18,180
Warsop
None gone caravannin
Have you tried all the burners on the hob, I can understand thermocouple failure on one but not on all of them, there may also be a bit of muck in the jet:thumb:
17,635
43,360
If its a blocked jet, this will give a weak flame, so not heating the thermocouple correctly
Mind you, we recently had a similar issue with the hob flame dropping by itself over time. Turned out to be a failing truma gas regulator, which couldnt keep up the supply.. In the end, it failed totally resulting in no gas getting through. Replaced it and sorted the problem, also fridge lights faster on gas than before
deanroofing
deanroofing
297
253
bedfordshire
since 2010
Tried all the hobs one did stay on a bit longer than the rest,when they go off it does seem like there is a cut off makes a noise, just tried again one stayed on for about 15-20 seconds the other two go out as soon as you release the knob.
Don't know if that gives any ideas, flame seems fierce enough on all burners.
TYKETRIPPER
43
9
North Lincolnshire
Van conversion
6 years
Gaslow regulator failure
If your gaslow regulator has a rubber hose then this is the problem. Please see follow sites. Link Removed
Had the same problem last year but soon fixed by a Gaslow dealer/fitter.
Hope this helps. Kind regards,
Ian
17,635
43,360
if the flame is fierce as you say, then it should heat the thermocouple. generally there is one for each burner. Another thought is air in the gas pipe. If you recently had work done on the gas or changed cylinders etc, it may be as simple as relighting the hob several times or holding in the knob to purge any air
The mechanical noise you describe is the flame failure device in the valve cutting off the gas as it failed to detect a flame
43,332
49,527
Hi Guys,
Thanks in advance.
Ian
i reckon that eliminates the regulator :thumb:
deanroofing
deanroofing
297
253
bedfordshire
since 2010
Got the stainless hoses, so thats not the problem, perhaps is the thermocouplers have to get my mate to have a look.
Thanks guys.
43,332
49,527
if the flame continues to burn with the knob held in then its almost certainly the thermocouple.
holding the knob in by-passes the thermo to allow it to heat up.
C.L.S
Trader - Service & Repairs
Jul 22, 2007
438
60
Not long enough
Sounds very much like your shut off switch is failing , I have replaced several of these under warranty for Thetford. Your dealer should be able to sort out for you and takes around 1 hour to undertake,
Thetford Part No. SSPA0600
Mark
17,635
43,360
Mark
That makes complete sense of course :thumb:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Just a thought but some that have a glass cover have a valve that opens to let the gas through only when the cover is up could it be be this playing up ?
11,843
14,080
I have the same problem. Johns Cross think it may just need the thermocouples tightening. It is going in to them on the 13th so they can play with it. I don't fiddle with the gas myself.
