Gas hob going out
Discussion in 'Tech/Mech General' started by deanroofing, Mar 3, 2012.
  1. deanroofing
    deanroofing Funster
    Nov 20, 2011
    290
    247
    bedfordshire
    Hi Guys,
    Got a problem with my gas hob, keeps going out on its own, it's a Thetford Spinflo, on a Gaslow system our blown gas which is a Truma Combi is working fine, any ideas or solutions would be gratefully received.
    Thanks in advance.
  2. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,370
    9,815
    sounds like the flame failure device cutting it off if the pressure is ok. This relies on a thermocouple that gets heated by the gas flame to keep the valve open. If for whatever reason the thermocouple is not being kept hot, the gas will shut off
    check that the thermocouple has not been dislodged when cleaning the hob and that you havent got a draft across it from an open window
  3. wasp
    wasp Funster
    Dec 21, 2008
    2,729
    1,066
    Mansfield
    Have you tried all the burners on the hob, I can understand thermocouple failure on one but not on all of them, there may also be a bit of muck in the jet:thumb:
  4. TheBig1
    Nov 27, 2011
    7,370
    9,815
    If its a blocked jet, this will give a weak flame, so not heating the thermocouple correctly
    Mind you, we recently had a similar issue with the hob flame dropping by itself over time. Turned out to be a failing truma gas regulator, which couldnt keep up the supply.. In the end, it failed totally resulting in no gas getting through. Replaced it and sorted the problem, also fridge lights faster on gas than before
  5. deanroofing
    deanroofing Funster
    Nov 20, 2011
    290
    247
    bedfordshire
    Tried all the hobs one did stay on a bit longer than the rest,when they go off it does seem like there is a cut off makes a noise, just tried again one stayed on for about 15-20 seconds the other two go out as soon as you release the knob.
    Don't know if that gives any ideas, flame seems fierce enough on all burners.
  6. TYKETRIPPER
    TYKETRIPPER Read Only Funster
    Nov 8, 2009
    43
    10
    North Lincolnshire
  7. TheBig1
    Nov 27, 2011
    7,370
    9,815
    if the flame is fierce as you say, then it should heat the thermocouple. generally there is one for each burner. Another thought is air in the gas pipe. If you recently had work done on the gas or changed cylinders etc, it may be as simple as relighting the hob several times or holding in the knob to purge any air
    The mechanical noise you describe is the flame failure device in the valve cutting off the gas as it failed to detect a flame
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,322
    YO11 2BD
    i reckon that eliminates the regulator :thumb:
  9. deanroofing
    deanroofing Funster
    Nov 20, 2011
    290
    247
    bedfordshire
    Got the stainless hoses, so thats not the problem, perhaps is the thermocouplers have to get my mate to have a look.
    Thanks guys.
  10. pappajohn
    Aug 26, 2007
    29,703
    17,322
    YO11 2BD
    if the flame continues to burn with the knob held in then its almost certainly the thermocouple.
    holding the knob in by-passes the thermo to allow it to heat up.
  11. TYKETRIPPER
    Nov 8, 2009
    43
    10
    North Lincolnshire
    Then just use it as info:Wink:
  12. C.L.S
    C.L.S Trader - Service & Repairs
    Jul 22, 2007
    410
    49
    Sounds very much like your shut off switch is failing , I have replaced several of these under warranty for Thetford. Your dealer should be able to sort out for you and takes around 1 hour to undertake,
    Thetford Part No. SSPA0600
    Mark
  13. TheBig1
    Nov 27, 2011
    7,370
    9,815
    That makes complete sense of course :thumb:
  14. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,068
    DERBYSHIRE
    Just a thought but some that have a glass cover have a valve that opens to let the gas through only when the cover is up could it be be this playing up ?
  15. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,755
    3,254
    Eastbourne East Sussex
    I have the same problem. Johns Cross think it may just need the thermocouples tightening. It is going in to them on the 13th so they can play with it. I don't fiddle with the gas myself.
