Fuse help (1 Viewer)
pvw10
273
45
Gloucester
Coach built
since 2011 after tugging.
Can anybody advise please ?
Under one bench seat behind the passenger seat is the usual fuse/relays that control the fridge and step, one is a 20amp fuse. This has blown but everything works, I have replaced it and it's just fine so question is what's it for ?
tonka
10,834
21,544
Cannock, Staffs
A class Burstner 800
Since 2000
Fridge ?? Maybe you would not notice if setting to 12v and then driving...
Charger ?? If you been on hook up maybe not noticed alternator not charging the LB.
Just ideas.. I aint got a clue really.... :)
pvw10
pvw10
273
45
Gloucester
Coach built
Ha ha like I said everything works with the fuse blown so confused.com
icantremember
8,336
17,554
Near to Watton in Norfolk
Hymer T-SL668
since 2005
If you have two leisure batteries, then this 20amp fuse may between them, in which case everything would probably continue working but only off one battery. If this is the case you need to find why the fuse has blown.
pvw10
pvw10
273
45
Gloucester
Coach built
Fair shout, I do have two but wrong side of the vehicle, both charge/discharge just fine.
It's an odd one for sure.
11,956
16,570
Leave it out - then wait until you find something that isn't working? Or replace the fuse with a 12v say 5 or 6 watt bulb. When / if the bulb glows something is trying to work via the fuse. Or replace the fuse with a meter set to 10A. When / if you get a reading something is trying to work via the fuse.
pvw10
pvw10
273
45
Gloucester
Coach built
Thanks but as I said it was blown when I found it and everything works ! I have now replaced it with obviously no change.
pvw10
pvw10
273
45
Gloucester
Coach built
Have a look here:
Top man thanks for this, mines on a Renault chassis with only 4 fuses and 2 relays from memory but some good info detailed.
I will get there I ain't giving up ......yet.
Spent ages this weekend whilst away, fuse out, running everything I could find on 12/240 & gas - the wife loved it, not.
And no, I found sod all.
