Fuse help
Discussion in 'Auto-Trail' started by pvw10, Aug 2, 2014.
  1. pvw10
    pvw10 Read Only Funster
    Mar 3, 2012
    274
    45
    Gloucester
    Can anybody advise please ?
    Under one bench seat behind the passenger seat is the usual fuse/relays that control the fridge and step, one is a 20amp fuse. This has blown but everything works, I have replaced it and it's just fine so question is what's it for ?
    • Like Like x 1
  2. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,435
    7,724
    Fridge ?? Maybe you would not notice if setting to 12v and then driving...
    Charger ?? If you been on hook up maybe not noticed alternator not charging the LB.
    Just ideas.. I aint got a clue really.... :)
    • Like Like x 1
  3. pvw10
    Mar 3, 2012
    274
    45
    Gloucester
    Ha ha like I said everything works with the fuse blown so confused.com
  4. icantremember
    icantremember Funster
    Sep 2, 2010
    5,220
    7,313
    Nr Watton in Norfolk
    If you have two leisure batteries, then this 20amp fuse may between them, in which case everything would probably continue working but only off one battery. If this is the case you need to find why the fuse has blown.
    • Like Like x 1
  5. pvw10
    Mar 3, 2012
    274
    45
    Gloucester
    Fair shout, I do have two but wrong side of the vehicle, both charge/discharge just fine.
    It's an odd one for sure.
    • Like Like x 1
  6. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,959
    2,783
    Kendal, Cumbria
    Leave it out - then wait until you find something that isn't working? Or replace the fuse with a 12v say 5 or 6 watt bulb. When / if the bulb glows something is trying to work via the fuse. Or replace the fuse with a meter set to 10A. When / if you get a reading something is trying to work via the fuse.
    • Like Like x 2
  7. pvw10
    Mar 3, 2012
    274
    45
    Gloucester
    Thanks but as I said it was blown when I found it and everything works ! I have now replaced it with obviously no change.
  8. icantremember
    Sep 2, 2010
    5,220
    7,313
    A 20amp fuse must mean it's there to protect something with a heavy power draw ... could be an inverter or solar panel feed.
    • Like Like x 1
  9. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    • Like Like x 1
  10. pvw10
    Mar 3, 2012
    274
    45
    Gloucester
    Top man thanks for this, mines on a Renault chassis with only 4 fuses and 2 relays from memory but some good info detailed.
    I will get there I ain't giving up ......yet.
    Spent ages this weekend whilst away, fuse out, running everything I could find on 12/240 & gas - the wife loved it, not.
    And no, I found sod all.
    • Like Like x 1
  11. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    • Like Like x 1
