fly cleaning (1 Viewer)
Scout
3,959
121,359
South Yorkshire
chic c line
its my first day off work since the france tour, so I treid cleaning the m/h, but the top front has more dead bugs on it than enought, I've tried just doing it with an extending bursh dipped in fenwicks, but their stuborn buggers, must have been limpet flys:ROFLMAO:
so it there a product to get them off with distroyed the gel coat or is it just get up real close and get scrubbing (trying not to fall of the ladders again :Doh:)
sides are easy pessy mind
Ps hurry and reply Ive only got a short tea break
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Did you use the red fenwicks motor home cleaner, I normally mix up a solution and spray on with a garden spray, then scrub with a long brush don't worry what it looks like at first, if need be do again, before washing off with bobby dazzler in the water then dry normally works for me.
Sometimes works better if you can catch between showers when the blighter's are damp.
Best of luck
Dave:thumb::thumb:
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
I have never found anything better than elbow grease. :ROFLMAO:
I try to soak them as much as possible before the big clean, then a damp cloth and lots of rubbing.
Scout
Scout
3,959
121,359
South Yorkshire
chic c line
Best of luck
Dave:thumb::thumb:
no mines yellow? didn't know it came in red? mine was lkeft over from the caravan, they do one just for m/hs
Im off for a google
Scout
Scout
3,959
121,359
South Yorkshire
chic c line
thats the rub (pun intented) without someone holding the ladders I cant get close to the buggers, I've done my best for now, I'll have wait for o/h to help
do scouts still do bob a job, its worth 5p to do it
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
To do the top front of mine I get onto the roof, lye flat on my front and reach down.
As far as whats to use is concerned its as above.
You may need a couple of goes if it is really bad.
Jim
:Smile:
DESCO
2,646
266
London
low profile
Im off for a google
Yes if you find Fenwicks motor home cleaner it should solve your problems:winky:and it works from the ground, have to do mine on my own wife's disabled so ladders not an option.
Dave:thumb::thumb:
Scout
Scout
3,959
121,359
South Yorkshire
chic c line
Dave:thumb::thumb:
yep just on been the site, looks ok to me, it'll still need a good rub though
nicklb
128
Bolton
Coach built
12 months
try a non scratch scourer and some light elbow grease, it works on mine, just ensure that you use NON SCRATCH, Vileda make them,
Why we are on the subject of cleaning (sorry to hijack your thread), does everyone stand on their roof, as I am very reluctant to?
43,332
49,504
cant remember the name but halfrauds do a winscreen cleaning foam that is designed to lift fly arse off screens and bonnet fronts.
43,332
49,504
sure do nick but at 17st i keep away from the roof lights/vents/overcab joint.:RollEyes:
nicklb
128
Bolton
Coach built
12 months
Must admit that at 15 st I am reluctant , we have a ladder and roof rack and top box, I am always trying not to touch the roof, I will try kneeling on it next time I am up, just hope I do not go through:whatthe:
savantuk
735
42
Cumbria, Lake district UK
30 years.
Fly and Tar removal spray from my local Poundland does the trick for me. A quick sprey, and then a rub with a cloth removes them PDQ:Smile:
An old trick that I read once also works well. An old string vest is 'rough' enough to remove them quite easily without damaging the paint. I'm clean out of string vests though......:roflmto:
43,332
49,504
ply skin and decor board inside, 1.5" to 2" polystyrene foam core, ply skin outside covered in a GRP/ABS moulding.
reckon you'de need to jump on it go go through.
reason i said avoid the vents/rooflights is its a weak point......open edges aint all that strong.
GJH
29,450
38,827
None, now sold
2006 to 2022
I've found those eraser foam blocks work well. They are sold in various shops under JML and Duzzit brand names (probably others too). Aldi do a version as well.
Graham
nicklb
128
Bolton
Coach built
12 months
You are starting to build my confidence :thumb:
haganap
12,760
26,461
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
sounds daft but I wait a good shower then drive the van on a good blast along the bypass. At 65 mph and heavy water on them those flies take off. If not its Fenwicks, elbow grease and a good scrubber.
Incidently I walk all over my roof without a problem, but im in the fly weight catogary but catchingup fast since stopping smoking.:winky:
