fly cleaning
Discussion in 'Motorhome Chat' started by SC 05 OUT, Sep 2, 2009.
  1. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,590
    doncaster
    its my first day off work since the france tour, so I treid cleaning the m/h, but the top front has more dead bugs on it than enought, I've tried just doing it with an extending bursh dipped in fenwicks, but their stuborn buggers, must have been limpet flys:Rofl1:
    so it there a product to get them off with distroyed the gel coat or is it just get up real close and get scrubbing (trying not to fall of the ladders again :Doh:)
    sides are easy pessy mind
    Ps hurry and reply Ive only got a short tea break
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    Tell them to get their own bloody shower. Hee hee
  3. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Did you use the red fenwicks motor home cleaner, I normally mix up a solution and spray on with a garden spray, then scrub with a long brush don't worry what it looks like at first, if need be do again, before washing off with bobby dazzler in the water then dry normally works for me.
    Sometimes works better if you can catch between showers when the blighter's are damp.
    Best of luck
    Dave:thumb::thumb:
  4. andyman
    andyman Funster
    Sep 23, 2007
    1,142
    494
    Leicestershire
    I have never found anything better than elbow grease. :Rofl1:
    I try to soak them as much as possible before the big clean, then a damp cloth and lots of rubbing.
  5. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,590
    doncaster
    no mines yellow? didn't know it came in red? mine was lkeft over from the caravan, they do one just for m/hs
    Im off for a google
  6. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,590
    doncaster
    thats the rub (pun intented) without someone holding the ladders I cant get close to the buggers, I've done my best for now, I'll have wait for o/h to help
    do scouts still do bob a job, its worth 5p to do it
  7. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    To do the top front of mine I get onto the roof, lye flat on my front and reach down.
    As far as whats to use is concerned its as above.
    You may need a couple of goes if it is really bad.
    Jim
    :Smile:
  8. DESCO
    Mar 11, 2009
    2,651
    267
    London
    Yes if you find Fenwicks motor home cleaner it should solve your problems:Wink:and it works from the ground, have to do mine on my own wife's disabled so ladders not an option.
    Dave:thumb::thumb:
  9. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,590
    doncaster
    yep just on been the site, looks ok to me, it'll still need a good rub though
  10. takeaflight
    takeaflight Read Only Funster
    Sep 4, 2007
    256
    Stratford-upon-Avon
    Baby Wipes !:thumb:
  11. nicklb
    nicklb Read Only Funster
    Jun 14, 2009
    128
    Bolton
    try a non scratch scourer and some light elbow grease, it works on mine, just ensure that you use NON SCRATCH, Vileda make them,
    Why we are on the subject of cleaning (sorry to hijack your thread), does everyone stand on their roof, as I am very reluctant to?
  12. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,698
    17,308
    YO11 2BD
    cant remember the name but halfrauds do a winscreen cleaning foam that is designed to lift fly arse off screens and bonnet fronts.
  13. pappajohn
    Aug 26, 2007
    29,698
    17,308
    YO11 2BD
    sure do nick but at 17st i keep away from the roof lights/vents/overcab joint.:RollEyes:
  14. nicklb
    Jun 14, 2009
    128
    Bolton
    Must admit that at 15 st I am reluctant , we have a ladder and roof rack and top box, I am always trying not to touch the roof, I will try kneeling on it next time I am up, just hope I do not go through:Eek!:
  15. savantuk
    savantuk Read Only Funster
    Jul 3, 2009
    751
    31
    Cumbria, Lake district UK
    Fly and Tar removal spray from my local Poundland does the trick for me. A quick sprey, and then a rub with a cloth removes them PDQ:Smile:
    An old trick that I read once also works well. An old string vest is 'rough' enough to remove them quite easily without damaging the paint. I'm clean out of string vests though......:Laughing:
  16. pappajohn
    Aug 26, 2007
    29,698
    17,308
    YO11 2BD
    ply skin and decor board inside, 1.5" to 2" polystyrene foam core, ply skin outside covered in a GRP/ABS moulding.
    reckon you'de need to jump on it go go through.
    reason i said avoid the vents/rooflights is its a weak point......open edges aint all that strong.
  17. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,327
    34,800
    I've found those eraser foam blocks work well. They are sold in various shops under JML and Duzzit brand names (probably others too). Aldi do a version as well.
    Graham
  18. nicklb
    Jun 14, 2009
    128
    Bolton
    You are starting to build my confidence :thumb:
  19. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,590
    doncaster
    :Rofl1:
    ha at a mere 16.75 stone im lightweight
    :Rofl1:
  20. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,129
    13,862
    Heavan
    sounds daft but I wait a good shower then drive the van on a good blast along the bypass. At 65 mph and heavy water on them those flies take off. If not its Fenwicks, elbow grease and a good scrubber.
    Incidently I walk all over my roof without a problem, but im in the fly weight catogary but catchingup fast since stopping smoking.:Wink:
