Filling a gas tank (1 Viewer)
Jun 6, 2012
1,141
1,545
Leeds
Since 2012
No, the fill valve is totally separate from your valve which supplies your MH therefore no need to shut off the supply, this is what I was advised when I had my refillable system fitted by Autogas2000 in Thirsk.
Regards David
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
When filling and the shut off operates DO NOT persist in holding the delivery button (trying to force more in) as this has been known to have a knock on effect on your outlet valve safety shut off.
scotjimland
2,335
10,108
A Woosh bang
Why do Broken Link Removed say:
1) Always ensure that the cylinder valve is switched off before filling
Feb 22, 2014
2,107
10,269
Grantham
Rapido Le Randonneur
Since 2015
Did mine for the first time ever today. First I couldn't get the nozzle off the pump. Then it was so SLOW filling up. Then I struggled to unhook it! But hey, it's done.
Minxy
32,656
66,564
E Yorks
Carthago Compactline
DBK
18,029
48,099
Plympton, Devon
PVC, Murvi Morocco
My 55 litre gas tank has no external shut off valve, do I need to shut off the gas
supply when filling the tank .
Are you sure it doesn't have a valve on the tank? On mine it is under the aluminium cover on the side. If you go on the chunnel you are likely to be asked to turn it off at the tank.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Pretty sure Dave means besides that
Minxy
32,656
66,564
E Yorks
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Can't remember where i got it from, might have been the conformity certificate.
Not to hand at the moment
Minxy
32,656
66,564
E Yorks
For the purposes of this thread though, and when talking about refillable containers generally, those that are permanently fixed and usually go underneath the chassis are called tanks, whereas those that are placed into a gas locker and look like exchange cylinders are called cylinders. :D
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Found it. I appreciate the thread is about fixed tanks.
Gaslow disagrees but the French authority class R67 cylinders as tanks.
Just to clarify.:winky:
Minxy
32,656
66,564
E Yorks
... but the French do what they like regardless ....:LOL:
Techno
Jul 28, 2010
15,475
20,756
May 2010
ok.. thanks for honesty , I will.
R67 is a French standard for LPG tanks.. EN1949:2011+A1..
R67 Galsow bottles comply with that standard
Design is still different to a Stako and why Gaslow say to shut the valve
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
You might wish to take a look at the filler the French use. It's an elegant and lightweight device that doesn't trap as much LPG between nozzle & filler valves. Leading to ease of use & a very small 'pfffst' upon removal. But we're British, we know better, so we designed our own. I have in mind a petite female attempting to use ours - but I don't suppose that there are many examples of that.
.Broken Link Removed
Jaws
23,836
72,492
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Had our Alugas system a couple of years before someone mentioned the valve should be closed when filling..
I had never done it and never had a problem..
No idea what is right or wrong but I am now about 6 years in to owning the system ( two separate vans ) and still cannot be arsed to close the valve when filling !! LOL !!
Nov 28, 2007
430
1,517
On Gaslow bottles if you don't shut them when filling you can pressurise the whole system and I believe force liquid gas into the pipes, it seems to stop the cut off working properly
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
On my Gasit bottles, I once forgot to turn off both bottles to the regulator. No gas would go in. As soon as I turned off the valves the bottles filled. In the process I had caused the 2 widgets that protect from a blown hose to set so when I went to use gas I could not until I reset them.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
We have a Gasit underslung tank, there is a valve on the tank ( under a remove able cover next to a gauge) and a yellow tap on the outlet hose.
I never shut off anything when I fill up ( nothing about this in the instructions) but shut off the yellow valve before boarding the Chunnel. No one has ever checked this tap because it means looking under the van!
JockandRita
11,462
150,163
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Although neither Gasit or Gaslow, we have the same set up, and never close the tank valve, other than prior to boarding our ferry...................even though we are never asked to, nor checked if we actually have. ;)
Cheers,
Jock. :)
