Exhaust pipe position (1 Viewer)
Traveller_HA5_3DOM
422
323
Following the Sun
Hobby Premium 65GE
since 1985
Our new Hobby, with the Renault front end has an exhaust pipe that ends in the centre of the vehicle. We spotted it when the Gas fitter was fitting the LPG tank last week and he said it was most unusual and was quite near to several drop vents, with the potential for pulling exhaust fumes into the vehicle under certain conditions.
I cannot remember seeing this arrangement before and wondered if any members have seen similar or if it is a matter governed by any Construction regulations, bearing in mind that it is built in Germany.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
Mine comes out of the side, too. Not a Fiat, though. It is a 1978 Chevrolet P30 based Winnebago Itasca. I'm sure I've seen lots of vans do this, even European ones.
Terry
11,943
9,138
Lincolnshire
Can't remember ;)
Mine also comes out of the side just behind the gas locker -Fiat/Ford Iveco ::bigsmile:
terry
Nov 6, 2008
3,944
40,801
Ramsey, Isle of Man.
Coachmen Concord 300TS
8 years with an RV
All exhausts should extend beyond the bodywork. Yours seems to contravene that.
Craig
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
Our old van was a bit smelly from the exhaust that was cut a bit short under the side of the van, ok under normal driving, but nearly every time we pulled up at lights or something like that it was coming in through the vents, so I bolted on an extension bit I picked up from the scrapyard, much better now:thumb:
you are surly going to have the same problem if it ends underneath the van, that seems to be a bit daft on a brand new Van:Doh:
TheBig1
17,653
43,496
I thought with modern vehicles it was a legal requirement that the exhaust should be expelled on the opposite side to the pavement relative to the steering wheel position. It sounds rather like the tail piece of your vans exhaust has been missed off
Feb 16, 2013
19,792
52,250
uttoxeter
ambulance conversion
50 years
Craig
Just had a look at my lads dethleffs and yeah it's almost dead centre underneath , took me a while to find it by looking from the sides, it is defected down though.:Eeek::Eeek:
Deflected even
3,944
40,801
8 years with an RV
Deflected even
Deflected down is just not good enough. When stationary, the toxic fumes will rise under the van, and penetrate any vents. Carbon Monoxide is lethal!
Craig
funflair
19,456
30,713
Guisborough
MORELO palace
since 2012
Iveco based N&B Flairs certainly our 2006 vintage all have the exhaust exiting bang in the middle of the chassis. I thought that this was giving us exhaust fumes inside so I extended the pipe out the side and then realised that the problem was actually a crack that I had not seen in the down pipe.
Now fitted new down pipe but left the side exit.
Martin
Feb 16, 2013
19,792
52,250
uttoxeter
50 years
Craig
Why has this only come to light now, johns van is 08 and the ops is nearly new so how many is there about, never heard about it before and this one is definitely original and nothing is missing it's got a proper bent down end.
Dazzlin
1,751
6,213
La Marina, Costa Blanca.
1986 Hymer A Class
From 2013
"with the Renault front end has an exhaust pipe that ends in the centre of the vehicle. We spotted it when the Gas fitter was fitting the LPG tank last week"
Hi. Slightly off topic but we have a 2007 renault master base and we told by THE gas fitter there was not room for an underslung tank. Could I ask what size tank and who fit it please.
Darren
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
mine is pointing down under the side of the van.
never had any problems with fumes inside the van mind it is a double floor van.
if you are concerned you could always fit some of the blown air style ducting on the exhaust and route it out of the back of the van.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
We have an exhaust that looks like a chrome drainpipe sticking out from under the van a couple of feet behind the drivers door.
Mrs A's car ( a Kia Carens) has an exhaust that points down a few inches back from the end of the rear bumper, it certainly doesnt extend beyond the bodywork. Its 3 years old.
Allan
Traveller_HA5_3DOM
Traveller_HA5_3DOM
422
323
Following the Sun
Hobby Premium 65GE
since 1985
Darren
Nice guy named Ian from motorhometech. He fitted the last van also a 2007 Renault Master with a 40 litre tank. He managed to get the same 40 litre between the chassis rails at the rear of our new Hobby, the 2014 latest Renault. He is mobile so comes to you. He works out of Nottingham.
We found that size tank is plenty big enough.
Feb 16, 2013
19,792
52,250
uttoxeter
50 years
then you lost the tailpipe somewhere...or the previous owner did..
the exhaust will always exit to one side or the rear.
usually a side exit is to the off side so pedestrians dont suffer.
I think you are wrong , the exhaust on johns van is definitely original , you couldn't attach a side piece as it's sort of up in the floor space behind the steps and finished off with a downward piece. Must be the same as the ops.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
The exhaust on a vauxhall vectra estate I had came no where near the rear of the car the pipe just pointed down behind the rear axle
meexi
89
103
Angus,Scotland
Hymer B694
since 2011
Exhaust pipe
If you are fitting the exhaust put it at the opposite side from the habitation door other wise you will fill an awning with smoke if fitted.
Feb 16, 2013
19,792
52,250
uttoxeter
50 years
Photo of exhaust under dethleffs esprite, with Renault base
Sorry it's upside down but you get the idea
198
161
North Wales
A class Carthago Chic I47
34 years
We got our Carthago from new Aug 2008 ten days later we were at Warrington after arranging to have air suspension on the rear end. When asked to move the camper over the pit it would not budge, the handbrake was stuck on. Our journey from home had only taken 30 mins or so but in that time the plastic type casing that covered the handbrake cable had melted, and it was seized solid. On checking underneath it was found that the very short pipe which came out of the baffle box did not extend through the hole in the alko chassis, but was curved downwards and positioned inches above this cable sheath. Five hours and two RAC trucks later, we were following our Retirement Machine 60 miles or so to Oldham Motors to be repaired. It took 6 weeks before we could bring it home, most of that time was spent in a battle between Lowdhams the supplier, Carthago the converters and alko the chassis makers. Then would you believe the new cable was sourced from Hymer you couldn't make it up could you ? Welcome to motor homing folks !!!
JockandRita
11,493
150,422
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Hi K----,
Not a Renault, I know, but our LHD Hymer on a Ducato 230/Alko chassis, has the exhaust tail pipe close to the middle of the vehicle, but pointing to the left. A previous owner has extended the tail pipe using one of the stainless steel extensions seen in a link provided earlier in the thread. It comes out from the bodywork, right underneath the bulk LPG tank.
I hope you find the answer you are looking for. :thumb:
See you and P------ soon. :Smile:
Cheers,
Jock.
