Dunlop Air suspension, fitting made easy guide (2 Viewers)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
For this job you will need some additional ground clearance (Milenco Quattros ideal)
A long handled torque wrench
Hammerite Waxoyl to coat all metal parts during assembly
A tape measure for LSV load sensing valve
1/2" drive sockets 13,17,22mm
Hammer, cold chisel, sidecutters, stanley knife, battery drill, 8mm HSS bit
Begin with the rod measurement at the LSV as this may alter with the suspension upgrade and need to be adjusted later BEFORE driving
Next having created more room for your comfort underneath the van if your bump stops are sat on the leaf springs? use your scissor jack to create a small amount of lift (about 25mm 1") make sure the head of the scissor is on a reinforced section of chassis
The bump stop will need a slight persuasion with a hammer and drift or cold chisel on the castellations to just start it off anticlockwise
BS removed
The basic components are superb quality and very robust
Upper bracket fitted and secured with bolt 17mm head
Next comes the removal of the leaf spring U bolts and bump stop bottom plate, 22mm socket and long handled wrench with some brute force to get these babies off
The bump stop plate is NOT replaced but saved for if you remove your kit to transfer to another vehicle.
Now attach a bellow unit to a bottom bracket loosely with the 13mm headed bolts and attach the appropriate air line (left or right) Marcle recommend red for left blue for right.
Compress the bellows until all the air is expelled and bend over the other end of the airline to prevent it re inflating, secure with tape or a small cable tie.
Bellows located
U bolted back in place 110nm tightening torque!
Allow the air back into the bellows and fit the top bolts loosly
tighten the bellows bottom bolts 13mm spanner, check alignment before tightening top bolts 13mm
Decide on a route for your airlines
View below rear of driver footwell where handbrake cable goes through to lever 2 x 8mm holes drilled
Airlines appear here and enter fill point and gauge
Units inflated
Now adjust the pressure until the units stand 13.5cm tall about 35psi and re measure the LSV ! remember mine was about 35mm in the first picture?
Now it is a tad under 30mm
Adjust here until it is the original measurement 8mm spanner to lossen the collar
This cost me ÂŁ411 as illustrated inc VAT n delivery
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Thanks for that very clear instructions, except where is the LSV located?
I have saved it as an html file for future reference, and it may be good to upload to the forum database downloads under Manuals - Accessories.
I think it should be under technical really but cannot find a category for that, maybe Jim might consider it as an addition. :Cool:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes agreed Keith I couldn't really find a good place to post it but happy for it to be moved anywhere more appropriate.
The LSV is recognisable by a rod and spring attached to the rear axle. With later vehicles with ABS this does not exist.
I should have said this example is x244 based and variations. There are kits for almost all vehicles and the X250 is very similar but without the LSV and a different top mounting plate.
keith
3,421
1,864
Ecclefechan
Done it.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Thank you for taking the trouble to post this I am sure it will help members on here:thumb:
sabconsulting
16
4
High Wycombe
Demountable truck camper
Where is the best place to buy these from?
This is very interesting; thanks for posting the photos.
I am interested in adding air suspension to the back of the Ford Ranger that carries our demountable camper - not that it sits too low or handles badly, but mainly as belt and braces to help take some of the load off the springs when off road.
Looking through various threads here people have provided links to companies that will install these systems, but I would want to install it myself (I can fabricate any additional steelwork necessary too) - any ideas who sells these kits at the best price for self-installation?
Thanks,
Steve.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Contact Marcle Leisure. They do various kits but more importantly they do all the parts as spares individually so you could just buy bellows and perhaps fab your own brackets with your skill?
I bought mine primarily over concern about the body roll and dreadful cornering and the back end lift is certainly a bonus for the steep ramps on some ferries.
I've realised as a bonus that the potential for levelling on site is enormous and cant wait for the opportunity to show off :ROFLMAO: not just rear up and down but SIDE to SIDE
I love to promote DIY and I've done quite a few topics now on various forums. Most stuff being based on my autocruise . ÂŁ411 for this system is a bargain or even less if you go for the plain filler points.
Apr 19, 2008
1,944
2,923
Kent coast Hythe
Rapido fiat based
brought first van 16 yrs ago
interesting thread. have air suspension fitted and checked over the weekend and noticed BUMP STOP perished, is this part of mot testing or do i need to remove them,
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Not sure what you mean? air assisted suspension usually replaces the bump stops
43,337
49,540
having to adjust the LSV means the body has been either raised or lowered...more likely raised.
your headlamps will probably need adjusting for the different rear ride height.
cab adjustable headlamp aim should be MOT'd at the 0 position on the adjusting wheel/knob and cant be used to adjust the height for MOT
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
The idea is to set your van level under all conditions and thus the headlight aim should not be affected. It's important that if you use the system as a leveling aid on site that you open the valves to equalise the suspension and re adjust the pressure for the road and re close the valves to prevent side to side transfer of air.
The BASIC air fill system cannot do this so the extra for the gauge/valve system illustrated is well worth it IMHO
sabconsulting
16
4
High Wycombe
Thanks - I've just checked their web site - ÂŁ411 does sound like a good price. ÂŁ470 for my pick-up for the complete kit.
Steve.
43,337
49,540
if you need to adjust the LSV actuating rod then you have altered the rear ride height from what it was without assister's and so altered the headlamp beam height.
admittedly, once a 'level' ride height pressure is set, and the beams adjusted to suit, there is no need to readjust headlamp beam height again.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I really think that if the difference was significant it would be mentioned in the manufacturer installation instructions. At worst it will lower the headlight beam by the teeny weeniest amount and the effect of fully inflating the units will only point them down more so so not likely to fail an MOT or blind oncoming traffic.
Point taken John but I'm not concerned
43,337
49,540
Fair comment....just pointing out a possible future pitfall....RE: MOT. :thumb:
Jul 4, 2010
1,194
804
Essex / central France
Hymer Star Line 680
9 years
I really think that if the difference was significant it would be mentioned in the manufacturer installation instructions. [HI]At worst it will lower the headlight beam by the teeny weeniest amount and the effect of fully inflating the units will only point them down more so so not likely to fail an MOT [/HI]or blind oncoming traffic.
I have a suspicion that low headlamps are also an MoT failure, but not 100%.
Apr 19, 2008
1,944
2,923
Kent coast Hythe
Rapido fiat based
Hi all readers, my query was i have air suspension fitted which assisted the suspension however bump stops are still visible but somewhat perished.
My question being if the bump stops are fitted do they play are part in the MOT , or do i remove them as the air suspension is fitted.
regards
ci carioca
west norfolk
low profile
6 months
air suspension kit dunlop
Hi There,
what i'd like to know is ,does it make the ride noticably more comfortablefor passengers in rear travel seats?
thanking you
ci carioca:RollEyes:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Well I don't have any rear passenger seats but I seriously doubt it would be any more comfortable. To improve handling and stop body roll implies SOLID
It's all about setting the air pressure to suit the terrain
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Left the van 2 weeks ago with 4bar in the springs and was all still there today.
I dropped the air to half a bar and the underside of the towbar stood at 11.75 inch.
pumped it back to 4 bar and it stood at 14.25 inch.
7 bar gives over 4inch rise :thumb:
Johnnie Gee
59
19
Near Aberdeen
Since 2000
Dunlop suspension kits
Marcle leisure supply them, along with the fitting instructions.
They are very helpful and will answer any questions you might have before buying. I fitted them on to my Hymer 584 and it made a tremendous difference to road holding, especially cornering and roundabouts.:thumb:
Hope you get the same results that I did.::bigsmile:
JJG
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Suspension latest
My van is in the process of being up plated from 3300kg to 3700kg
The fee is ÂŁ240+VAT
I've contacted my insurance Safeguard and confirmed that this will not affect my policy or my AA breakdown/recovery.
So an extra 880lbs payload for ÂŁ288 and cheaper road tax
buffallobill
58
54
skipton
since2007
Hi. Tnechno100, in the photo where it states inflate unit to 13.5cm is that the measurement of the bellows height, or is it 13.5 cm from chassis to top of spring. Thank you in anticipation of your reply, bill
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Hi blufalobill
It is a long time ago now but I don't think it is that critical and 35psi is mentioned.
I believe I was quoting the supplied instructions and the fact that it says the "units" would indicate that it means just that.
If in doubt give Steve a call at marcle leisure.
Edit actually the psi is not a good guide as the weight of the vehicle will change that significantly to achieve 13.5 cm
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Sorry to contradict John that is not correct:Sad:
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Hi blufalobill
Just out of interest, where did you buy the twin reading gauge??? Dave Newell fitted ours, (and a nice job he did do), but messing about with a tyre pressure gauge is a pain. :Smile:
