Ducato Heater Blower not working. (1 Viewer)
Oct 8, 2014
1,641
3,031
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
This might be of help to people in the future .......
Last week I discovered that my heater blower is only working on speed #4.
Research on the internet points to it being a faulty Blower Motor Resistor. On my RHD Ducato this is mounted on the blower motor, above the passenger footwell. Removing the Resistor is fairly easy, (if you are an agile midget) as it is held in with one screw. However, once the screw is removed, you have to depress a clip next to the screw and slide the assembly sideways, to disengage four small lugs. It then pulls outwards.
I checked the resistances, and the fuse and all seem OK ... none open circuit, though I dont know what the values should be. However, when I examined the plug, one connection has obviously overheated.
More internet research brought up this...
http://www.heaterblowerresistor.co.uk/fiatdobloducatoheaterresistor.html
I have ordered a loom repair kit and also a new resistor assembly, so I will have a spare, even if my existing one turns out to be serviceable.
John
23,836
72,509
Had the same.. Cut the plug off and silver soldered the wires straight on to the resistor ..
Though me being me I bought a resistor first so it was ready to fit.. Ended up giving it away !
Revolvor
Oct 8, 2014
1,641
3,031
Wiltshire
John
The replacement Resistor and Loom repair kit arrived the next day. I cut off the old plug, and soldered/heatshrunk the new one, fitted the new resistor and it now all works.
However, information enclosed with the new resistor warned that resistors usually fail due to overheating, and a common cause is a blocked pollen filter that reduces the airflow. I have now ordered a new pollen filter!!
For those of you with a Ducato base vehicle, @Techno recently posted this. Thanks Andy, I hope to do it next week.
http://www.motorhomefun.co.uk/forum/threads/x250-pollen-filter-change-in-pictures.80174/
Jan 8, 2013
8,490
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Well yesterday I followed Techno's instructions for changing the pollen filter after I had half the dash on the floor I found my 2012 van hasn't got one! Or any place to fit it. Any body want to buy a brand new filter?? It does have a corse filter under the bonnet, you can even put your hand in and feel the heat fan blades. Bugger! Should have tried that first.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Interesting but photos would have been useful
I'm not aware that any x250 cabs don't have a pollen filter
It's only the glove box if you're stripping the dash you're in the wrong place
Jan 8, 2013
8,490
11,530
Burstner Lyseo 690G
Behind the glove box and exposing the fan motor. You can see the fan vane's from inside the bonnet inlet. There seems to be no place for the 9" square filter to fit.
Techno
Jul 28, 2010
15,475
20,756
May 2010
The central glove box
You are in the wrong place
I don't understand the confusion as the passenger glove box bears no resemblance to the pictures in my guide
8,490
11,530
Burstner Lyseo 690G
I'm in Germany so I can't see the pictures very well on this phone. I'll try the central glove box next?
Techno
Jul 28, 2010
15,475
20,756
May 2010
There's no point working blindly in the wrong place when I did all the hard work with pictures to make it easy :unsure:
Jan 8, 2013
8,490
11,530
Burstner Lyseo 690G
Right - I've taken out a dozen screws and everything is loose but the glove box or the inner liner is not coming down or out. Can you send me the link again, it disappeared on this phone
Jan 8, 2013
8,490
11,530
Burstner Lyseo 690G
Sorted - it's a doddle. No it's not it's a complete pig. It took me over half an hour. Wouldn't be so bad if there was more room between the seats. I would guess they designed it for the van but then decided to fit a glove box in front of it. After 4years and 30,000 miles I would say it was half done. But I'm happy to know I have a brand new one in there. Thanks to Techno.
