Doh!!! Battery (2 Viewers)
Busman
1,766
4,332
Wirral
Esterel
A few years
First mistake, thought I'd turned lights off but left sidelights on so battery flat. I've charged the battery up but I still can't get passed the immobiliser/alarm, I've asked the previous owner who said he'd had the battery out before with no problem, any ideas please. Thanks Dave
MikeD
3,936
3,697
London
IH PVC
Is it a makers or after market fit?
It must be confusing why it does not work, I don't think I have ever had one that does not just reset it self. :Eeek::Eeek:
Mike
43,332
49,505
a wild guess.....
It may be (most likely) on a rolling code and the code is out of sync.
Immob is expecting one code and the fob is sending a dfferent one.
How to re-sync...no idea.
Busman
Busman
1,766
4,332
Wirral
Esterel
A few years
The fob works the doors etc then you put a code on a pad on the windscreen then turn ignition. When I put the key in and turn I can hear a whir sound, think it might be time to get the recovery out,
Thanks for the replys.
Dave
43,332
49,505
Dave
that sounds very much like a starter motor fault....sticking pre-engaged bendix.
If you can get to the starter motor give it a good tap with a hammer...usually free's it off unless the solenoid has failed.
Jan 22, 2013
1,254
60,428
London SE
A class Adria vision I707
since 1971
[QUOTE When I put the key in and turn I can hear a whir sound, think it might be time to get the recovery out,
Dave[/QUOTE]
Hi Dave I would check the battery voltage, it sounds like it's still flat, the whirring sound is possibly the starter turning over very slowly and not engaging the bedix, some time it can sound like a machine gun that when the solenoid engages and as the starter motor load comes on song the voltage drops and disengages the solenoid, then the cycle repeats it self
Busman
Busman
1,766
4,332
Wirral
Esterel
A few years
Pappajohn & Ivorantony will check both them out makes you think could be either
Dave
Busman
Busman
1,766
4,332
Wirral
Esterel
A few years
Mike
Well noticed no ones called me a idiot yet well that could be about to change. The battery was indeed flat and I did charge it up ok and the immobiliser did reset itself it's just I was putting the wrong code in, before I realised the battery was flat I was doing the correct code but tried another input code then realised flat battery, when the battery was recharged I was still doing the changed (not right) code.
Again thanks for the help and a wee dram to you in the future.
Dave
:Doh::Doh::Doh::Doh:
MikeD
3,936
3,697
London
IH PVC
Well it wont be me!
Dave
Dave
We have all done something like that before. I am just pleased its all sorted out. :thumb::thumb:
Mike ::bigsmile:::bigsmile:
