Doh!!! Battery
Discussion in 'Tech/Mech General' started by Busman, Jan 11, 2014.
  1. Busman
    Busman Funster
    Jul 25, 2013
    872
    1,685
    Wirral
    First mistake, thought I'd turned lights off but left sidelights on so battery flat. I've charged the battery up but I still can't get passed the immobiliser/alarm, I've asked the previous owner who said he'd had the battery out before with no problem, any ideas please. Thanks Dave
  2. MikeD
    MikeD Funster
    Dec 21, 2011
    2,132
    1,869
    London
    Is it a makers or after market fit?
    It must be confusing why it does not work, I don't think I have ever had one that does not just reset it self. :Eeek::Eeek:
    Mike
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,952
    17,628
    YO11 2BD
    a wild guess.....
    It may be (most likely) on a rolling code and the code is out of sync.
    Immob is expecting one code and the fob is sending a dfferent one.
    How to re-sync...no idea.
  4. Busman
    Busman Funster
    Jul 25, 2013
    872
    1,685
    Wirral
    The fob works the doors etc then you put a code on a pad on the windscreen then turn ignition. When I put the key in and turn I can hear a whir sound, think it might be time to get the recovery out,
    Thanks for the replys.
    Dave
  5. MikeD
    MikeD Funster
    Dec 21, 2011
    2,132
    1,869
    London
  6. pappajohn
    Aug 26, 2007
    29,952
    17,628
    YO11 2BD
    that sounds very much like a starter motor fault....sticking pre-engaged bendix.
    If you can get to the starter motor give it a good tap with a hammer...usually free's it off unless the solenoid has failed.
  7. ivorantony
    ivorantony Funster
    Jan 22, 2013
    508
    539
    London SE
    [QUOTE When I put the key in and turn I can hear a whir sound, think it might be time to get the recovery out,
    Dave[/QUOTE]
    Hi Dave I would check the battery voltage, it sounds like it's still flat, the whirring sound is possibly the starter turning over very slowly and not engaging the bedix, some time it can sound like a machine gun that when the solenoid engages and as the starter motor load comes on song the voltage drops and disengages the solenoid, then the cycle repeats it self
    • Like Like x 1
  8. Busman
    Busman Funster
    Jul 25, 2013
    872
    1,685
    Wirral
    Pappajohn & Ivorantony will check both them out makes you think could be either
    Dave
  9. Busman
    Busman Funster
    Jul 25, 2013
    872
    1,685
    Wirral
    Well noticed no ones called me a idiot yet well that could be about to change. The battery was indeed flat and I did charge it up ok and the immobiliser did reset itself it's just I was putting the wrong code in, before I realised the battery was flat I was doing the correct code but tried another input code then realised flat battery, when the battery was recharged I was still doing the changed (not right) code.
    Again thanks for the help and a wee dram to you in the future.
    Dave
    :Doh::Doh::Doh::Doh:
  10. MikeD
    MikeD Funster
    Dec 21, 2011
    2,132
    1,869
    London
    Well it wont be me!
    Dave
    We have all done something like that before. I am just pleased its all sorted out. :thumb::thumb:
    Mike :BigGrin::BigGrin:
