Does anyone actually use cruise control? (3 Viewers)
joncris
1,101
1,603
Where it matters
Rimor Katamarano 12p +
I wouldn't have a MH or car these days without one. The slightest touch of the clutch (and it is a slight touch, not enough to do anything other than disconnect the cruise) or brakes in my Fiat ducato disconnects it so in traffic, touch the clutch, no brake lights to confuse following vehicles, and re engage when new speed is reached after normal engine braking. Very relaxing, no aching right foot on long trips. Brilliant. Try one, you won't go back.
Mines all controlled by buttons on the steering wheel. If I want to disengage it I press a button
Nel
10
Peebles
auto-cruise alto
off and on since 2005
I cant make up m mind. Try it to keep within speed limits them I need to pass someone. Bit of a faff
Badknee
7,408
412,945
notloB
Vantage Neo
Living the dream.
Having just bought our MoHo it was the first extra on the list along with reversing cameras, Dave Newall fitted ours and it's brilliant.
DanielFord
3,020
3,086
No need to disengage in this scenario, depress accelerator whilst passing. Release accelerator when finished and the vehicle will coast back down to preset speed.
Ian37
40
65
london
I use it in the car and my motorbike . Don't have it in the camper :(,
May 20, 2009
785
865
Haute Vienne, France
Would use on the MH if I had it as it is a pain in the right ankle to try and keep a constant speed when going down to Spain:(. Use it in the car most of the time especially on motorways.
Nov 25, 2014
30
18
Waterlooville
Carthago Chic I51
Since 2015.
I use it when ever possible in the car, it saves money and keeps me within the law. My setup will either maintain a given speed or stop me from exceeding a given speed. I know it is fitted to our new MH and I would expect to use it all the time. Strangely, my wife never thinks to use it, she would "rather be in control"!
TerryL
6,188
8,191
North East
Low Profile
Got used to cruise control when I was driving coaches - but then you "cruised" as fast as the governor would let you. We always felt, however, that if we tried, we could get better fuel consumption without it.
In the car I've got both CC and speed limiter and use them much of the time when conditions permit, although often I'm dropping in and out 'cos of other traffic.
In the M/H I only tend to use it on fairly level fast roads, motorways etc. as although the engine will quite willingly struggle it up hills, it then "holds back" going down them and consequently the fuel consumption suffers - I can do much better myself.
Wouldn't be without it however.
Sep 2, 2014
1,023
5,392
Gloucester
Self-converted Van
Since 2014
I have it on my car and now use it as often as I can, particularly to keep to speed limits as I have no wish to purchase another speed awareness course! Would probably use it on the motorhome if Ron would ever let me drive it!
Oct 27, 2013
712
11,116
Portglenone, Northern Ireland.
Elddis Magnum185GT
Since July 2012
Always use it in the MoHo when I can but the only thing that bugs me about the Fiat system is you get no indication if it's engaged or not; you only get the green speedo icon to tell you it's on. In the car I get "cruise" when switched on, then "On" when selected. If there is no "On" then it's Off :confused::confused::confused:
I know what I mean anyway ;)
Traveller_HA5_3DOM
422
323
Following the Sun
Hobby Premium 65GE
since 1985
Love it and providing you get used to looking well ahead and keeping a good distance from vehicles you have no intention of overtaking it is a real asset. The Renault Master also has a speed limiter that you can set in the same way as the Cruise. It means you can drop under the speed you set but unless you kick down it will keep you at whatever speed you set it to. Just what you want in Speed limit areas.
BobtheBass
Nov 11, 2013
1,959
6,893
Tewkesbury
Hymer T-SL 668
March 2014
I must say that I have been surprised by the overwhelming support for cruising! When I get the new m/h in January I will have to master the thing no matter how long it takes.
23,836
72,510
There is an oddity on the 2.3 litre Fiat set up.. I was talking to a chap on a site in Prague during the summer and he mentioned it.. I thought it was just me but nope..
The CC is ( obviously :) ) linked to the ECU
Somehow ( even though there is absolutely no mention of it that I can find anywhere ) when you have the CC on the torque available goes up considerably.
On looooongggggg steep inclines we found the van struggled sometimes.. On occasion dropping down as low as third ( 6 speed box )
I tried dropping it down just one gear, and pressing resume.
Every time the van went straight back up to cruise speed .. Try to do it without using the CC and it would struggle like buggery !
Sep 23, 2013
2,585
8,774
Lincs
Globecar Campscout
Mentioned on here before, but probably worth repeating.
The operation of the current Fiat cruise control is not as set out in the manual. I don't have the manual to hand, so can't remember exactly what it says, but what works is this:
Switch on cruise control using the On/Off ring on the stalk.
Get up to your chosen cruising speed. Activate cruise control at that speed by flicking the stalk upwards. (That's the bit that differs from the manual)
Sit back & relax.
Cruise control can now be deactivated/reactivated by a press of the button on the end of the stalk. Speed can be increased or decreased in small increments by flicking the stalk up or down. Holding the stalk up or down will result in a gradual increase or decrease in the set speed.
It took me a while to work out why I was having such difficulty getting the cruise control to engage. I think the manual tells you to use the button to engage rather than flicking the stalk upwards.
As always, a touch on the brake (& the clutch if you have a manual) deactivates in the same way as the button on the end of the stalk.
Pudsey Bear
80
45
Keighley, West Yorkshire
We had one in the Laika, and I bought one for the self build, but I sold it as the pedal is in a nice place to run consistently at almost any speed, very useful when going through spec cameras in the car, I'm amazed at how many vehicles come flying up to the cameras, slow right down then off again til the next one, do they have no sense at all.
PJGWiltshire
1,384
1,791
Arundel
since 2009
Would not be without, just got to plan ahead on long hill climbs, as if you let the CC try and get you up it just cuts out and if its the first time you experience this you think you have blown up the engine
Brian and Jo
3,002
6,447
oswestry,shropshire
A-Class N+B Arto 88F
Been motorhoming for 15yrs.had an American RV for 7yrs,Now got a Niesmann Bischoff Arto 88F
yes use it all the time.it enables you to get the best out of the fuel (mpg) and its relaxing when you are driving.had it on the RV,got it on my F150 pick up and its going to be on the NB that we have coming in March.wouldnt be without it.
Brian & Jo
mentaliss
654
306
Lancing
I have tried many times to use the cruise control on our cars and motorhome, yet cant get the feeling that the vehicle is slightly out of control from my mind. I know I have friends who use it all the time and wouldn't be without, but I never feel happy when its on. It just makes me nervous. How does everyone else feel? Is it me? Am I being paranoid?
Every European trip...dead easy to use:)(y)(y)(y)(y)
weejohnw
238
84
Richhill
Started August 2008
Great on flatish motorways. Found I could manage better MPG figures without it either going up or down inclines. On a long journey however CC provides for a relaxing drive which gives the arthritis a rest in the right ankle. CC not much use on a busy motorway as you are constantly having to adjust your speed to overtake or brake to let ejits back into a lane when they decide to start pulling in before they have actually passed you. Great on the less busy roads in France/Germany. Overall, useful to have, IMO.
Bulawayo Lass
255
323
Mud Island, nr Mudchester
long (with Brian) short (alone) medium (with Andy)
All the time in the car it is an automatic with cruise control so makes driving comfy. And about 60% of the time in CB l used it loads more but now trying to do more going up hills to save fuel.
joncris
1,101
1,603
Where it matters
In our Renault MH the CC set speed is shown in the display so if you brake or excelerate then press resume you know the speed it will return to
deanroofing
297
253
bedfordshire
since 2010
Love cruise control saves fuel, the wife is heavy footed she's anti cruise control
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
I was told by a police traffic officer friend of mine that it is not safe to use on wet roads due to possibility of loss of control before you could react and deactivate the CC, he said that he went to a bad accident on the A47 which was a result of using CC in the wet, took some time to figure out what happened, not a M/H by the way. That's what I was advised.
Apr 13, 2012
5,545
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
Always the odd one out...... I don't use CC.....can't be bothered.... and I find not slowing on bends that I feel a bit out of control...............
