Apart from the fact that the gas inside has to be recovered for it to be legal.Which , unless you are a fridge engineer with a recovery machine or have a mate who is one , means you'll be illegally venting !Should be an easy DIY job, can't be much different to changing a rooflight apart from removing the wiring. It will be a 240v supply so best to disconnect at the consumer unit then you can either remove the wiring or leave in place.
My thoughts too. Exactly same as removing a fridge or freezer, only have to de-gas to legally dispose of unit I would have thought.surely the gas will be in a self contained unit so needn't be disturbed,
No problem if it is a self-contained unit.I was thinking more that it would be a split.surely the gas will be in a self contained unit so needn't be disturbed,
they can weigh from 30 to 45 kg
I would levee the wiring as it could be used for roof mounted solder panels it would save on a cable run and additional holes being drilled in the roof if the isn't al readyShould be an easy DIY job, can't be much different to changing a rooflight apart from removing the wiring. It will be a 240v supply so best to disconnect at the consumer unit then you can either remove the wiring or leave in place.
We have a fantastic fan can confirm they are good.
Centre one so it's above the kitchen, factory fitted, a Hymer option.did you get it fitted or DIY. front or rear skylight?
Ralphs just put one if these on Pug. See link. I supose it would depend on the size of the opening your left with , as to what you can fit. Or get fitted.Maybe consider fitting a roof mounted fantastic fan at same time
Hymer don't use Heki the large frong roof light is custom to Hymer they only wide up.do you have a large Heki in front? can they fit them into existing Heki? a pic would be nice...
I suppose I'll have to go and take some photos.
Just for you Judge.
Best sealant to use? Should I just leave the inverter in, can it be utilised?
Im sure the "Itinerants" will think of this when fly tipping old fridges.surely the gas will be in a self contained unit so needn't be disturbed,
