Cost to remove roof aircon (2 Viewers)
Nov 6, 2011
438
656
Worthing
Knaus Sky Ti
2001 to date
Anyone removed roof mounted aircon and replaced with rooflight. Any idea of cost involved, or is it an easy DIY?
Keith :cool:
53,495
150,308
Should be an easy DIY job, can't be much different to changing a rooflight apart from removing the wiring. It will be a 240v supply so best to disconnect at the consumer unit then you can either remove the wiring or leave in place.
Mousy
3,486
20,326
Sa15 2DG
Hymer S840 Merc auto
It's a very easy DIY job if you drive under a low bridge. You might not appreciate the slightly rough finish though:rofl:
Aug 18, 2014
23,806
133,942
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Apart from the fact that the gas inside has to be recovered for it to be legal.Which , unless you are a fridge engineer with a recovery machine or have a mate who is one , means you'll be illegally venting !
Wickolad
490
542
Wickersley
surely the gas will be in a self contained unit so needn't be disturbed,
My thoughts too.(y) Exactly same as removing a fridge or freezer, only have to de-gas to legally dispose of unit I would have thought.
lunarman
2,156
2,451
South Glos
since 1994
Should be a simple job as they normally fit straight into a 400x400 opening. 4 through bolts one in each corner.
However you will need help getting it down off the roof, depending on the model they can weigh from 30 to 45 kg
Jan 28, 2008
10,121
18,390
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
self contained unit so no need to de-gas , just replace with a rooflight easy enough job you will need access to the roof and some sharp blades and scrapers to cut through any mastic
Nov 18, 2011
11,862
43,069
Planet Earth
A van
Over 25 year's
I would levee the wiring as it could be used for roof mounted solder panels it would save on a cable run and additional holes being drilled in the roof if the isn't al ready
bill
2,353
10,221
As said, straightforward DIY job , cost will be the cost of roof light £50 - £269 http://www.olearymotorhomes.co.uk/rooflights--accessories-21-c.asp
dealer will charge probably 3 to 4 hours labour . @£50 per hour.. + materials say £200 labour + £ 75 materials.. so budget on £300
If the aircon is serviceable, sell it on ebay .. new ones are just shy of a grand.. so it may just cover the cost.
Nov 30, 2009
6,548
149,046
Pickering
PVC the PUG
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
Centre one so it's above the kitchen, factory fitted, a Hymer option.
do you have a large Heki in front? can they fit them into existing Heki? a pic would be nice... :)
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
Please be aware that any venting of an f gas carries a 25 grand fine , so be carefull , and if its an old one with r22 gas in it you wil not be able to sell it , it will have to be disposed through a registered reclaim facility
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
1994 and beyond...
Hymer don't use Heki the large frong roof light is custom to Hymer they only wide up.
I suppose I'll have to go and take some photos:).
sorry my point was do they fit it to existing window or is it a complete unit
53,495
150,308
Just for you Judge.:)
Front rooflight closed.
Front rooflight open, side view
Pikeman
Nov 6, 2011
438
656
Worthing
Knaus Sky Ti
2001 to date
Hi Folks,
Am revisiting this thread as just got back from getting a quote for removing aircon and replacing with roof light. The dealer was not really interested in doing the job and could not fit it in for at least two Months. Quote was (basic roof light) fitted £250. Fair I suppose, but am considering the DIY option. Have investigated the hole as a standard 400mm square. Turns out the aircon has an inverter concealed behind passenger seat.
Questions; Best sealant to use? Should I just leave the inverter in, can it be utilised?
Cheers,
Keith :cool:
Pikeman
Nov 6, 2011
438
656
Worthing
Knaus Sky Ti
2001 to date
Come on you lot, I'm after your wisdom here. Stop talking about pets and stuff, lets talk MH's.
Jan 28, 2008
10,121
18,390
Renalt burstner
yes you can leave the invetor in just disconnect the wires that feed the aircon and add a plug socket it may even have a plug socket on the invertor already
you obviusly need the right sized poof light to fit the appeture and some mastic sealing //bedding tape it is a simple enough job if your a competent diyer
2,353
10,221
This has been debated a couple of times.. Sikaflex or Mastic ..
I would use Carafax IDL 99 , a non-setting mastic that will flex and allow the roof and window to expand and contract without breaking the seal.. Or the same stuff on a mastic bedding strip that is easier and less messy to apply.. buy the correct width to suit the window seal ..
Clean the roof around the aperture with white spirit .. then apply mastic or sealing strip.. When you fix the window it should be pulled up just tight enough to compress the mastic, but not too much that it expels it all. Clean off any excess mastic with white spirit .
The inverter can be used as any other you would buy.. as said above..
Pikeman
Nov 6, 2011
438
656
Worthing
Knaus Sky Ti
2001 to date
Thanks for the input folks. Am now working on getting the thing off the roof - it weighs 42.5 Kgs. Think I am going to have to take it to work and use the fork lift for this.
Cheers
Keith :cool:
PeteH
6,853
9,032
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Tongue in cheek lateral thinking:- Attach Trailer to Motor-home, Find Bridge or overpass on quiet road and park underneath, Sling Block and tackle on said bridge , Hoist A/C Unit and tie off, drive forward until over trailer, Lower into trailer, Un-ship Tackle and go home Job Done!!!.:D:D:D:D
Pete.
