About £430 with the new controller, polystyrene, expanding foam, VT9 stat and switches.Hi Richard&Ann if you don't mind can you tell me roughly what this would cost to do
Yes, theoretically easier. You just need to change the compressor to a 12v one.Hi Richard&Ann can this be done to a Domestic fridge with freezer on top
Did you mean Dometic?Hi Richard&Ann can this be done to a Domestic fridge with freezer on top
Thanks Lenny HB this is the trouble with getting oldDid you mean Dometic?
Your work bench could do with a sweep offBeen trying to keep busy over the last 2 days so I started my compressor project. Mainly to save gas and the inconvenience of filling up, the compressor fridge will run off solar easily but even if the battery gets a bit low you can fit a resistor to the controller so it will switch off at 11v (default is 9.6v).
First job was remove all the absorption gubbins and just keep the insulated box... View attachment 625691
I see the heat transfer paste is still good from I think 2017
80ah gel battery and 150w solar panel tiltable for use in autum in Benidorm. Wouldn't keep up in winter without engine running every other day.…may have missed it but what solar / battery set up do you have?
Delighted can't remember the last time I filled the LPG bottles must have been in Benidorm in 2021... And I'm still on the 1st bottleBet you’re pleased with how it is working.
