Converting our 3 way fridge to compressor. (1 Viewer)
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
Been trying to keep busy over the last 2 days so I started my compressor project. Mainly to save gas and the inconvenience of filling up, the compressor fridge will run off solar easily but even if the battery gets a bit low you can fit a resistor to the controller so it will switch off at 11v (default is 9.6v).
First job was remove all the absorption gubbins and just keep the insulated box...
I see the heat transfer paste is still good from I think 2017 🤔😏
Richard n Ann
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
Oh forgot to say, I bought this the other week, I did some measuring up and all is good. Our fridge is the Dometic RMS8400 👍
Richard n Ann
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
Then to the back and started building it back up with 1" polystyrene sheets and expanding foam for the gaps. Got 3 in to bring the back flush again.
I've lagged the suction, as is usual procedure, stops condensation running down it and the cool gas back helps to cool the compressor. (some compressors actually overheat without it)
Richard n Ann
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
I fitted a tube for the stat phial so it can be replaced. The condenser unit is on angle aloominum as the back is just that silver cardboard stuff..
Oct 11, 2019
926
3,539
Cheshire
Converting a Van
I'm a Total Newbie!
Very interesting and you seem to know what you're doing. How much does the conversation cost? How many amps a day do you reckon it will use?
Well done for keeping busy. 👍
Richard n Ann
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
I posted a link to the kit, was about £364 but it's gone up 15 quid now, after that all you need is the acrilic sheet, 9 pound something, polystyrene available on ebay and expanding foam.
Power consumption wise I think I read somewhere it averages at 1ah so 24ah per day 👍
Swifter
3,914
9,042
Herefordshire, UK
Since 2019
Brilliant thread . Fantastic advice and photos .
It’s also the time of year we normally get hot weather in the U.K. so we can expect to see the pictures of that awesome fan unit you made for the skylight and the modified fan speed for night time . Just hope the weather comes soon .
Keep posting this kind of stuff buddy . I love it 👍🏻
Richard n Ann
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
Not impressed with the thermostat it's switching the compressor on every 6.5 minutes (no wonder it maintains a steady temperature). The diff must only be 2°c. On a domestic fridge auto defrost stat the diff is more like 18 so the compressor runs longer but then stays off longer to defrost the evaporator.
I can always fit a digital thermostat later I suppose, I just begrudge the 50ma quiescent current 😆
Run time 1m 37s
Off time 6m 36s
Internal temp 3.5°c
Also the first 30 seconds running is at 3.8amp but then it drops to 2.8amps for the remaining run time. So the less start ups it does the less the power used.
Maybe the compressor runs slightly faster at first but can't hear any change in speed.
I've reset the battery monitor AH counter and switched off the charger so we'll see how many AH it uses over the next 12hours. The night usage is the important bit of course, the solar's there in the day so who cares about that 😊👍
RedFrame
1,297
3,684
Chester
Self Build W907 PVC
Sept 2017
I've been running a 12v Dellonda compressor fridge freezer constantly for the last 10 months or so. As a ball park comparison ...
At 5 deg/-18 deg I get 6 min run time and 12 min quiet.
Overnight Jan/Feb, I find approx 20a is drawn.
Is there a reason you run at 3.5 deg ? Food standards only require 5 deg, raising it may improve performance without any harm...
Red
Richard n Ann
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
It's about 4c at the top and the lower sensor is on 3.3c so I could higher it slightly 👍
Richard n Ann
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
It's just coming up 12 hours then, think I reset the AH counter about 6.15pm. Only 7AH used since and the single 80AH battery is still above 80%, I'm under no illusion though, it would probably use double in spain. Internal temperature has dropped slightly but been pretty steady.
Starting up about 5.3 times every hour so better.
Bolti
1,306
3,664
Hondon Valley and the Kellets
Rapido V43
Since 2015
Most impressed and if you ever need an apprentice would you consider me please.
I have a compressor fridge Vitrifigo 90L and even on half setting things often freeze on the top shelf below the freezer box.
Richard n Ann
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
What's the freezer temperature? If that's plenty cold enough you can replace the thermostat, if it's not it's just how the fridge is.
Richard n Ann
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
I'm keeping the fridge fans, they probably won't run much mind.
I've blocked off the surround so they'll extract properly if they come on.
I'm cable tieing the sensor on the compressor discharge pipe, it will bring the fans on if it gets to about 45°c
The external covers will need to be on most of the time too, otherwise a gale will be blowing in round the fridge as the aluminium cowling has now gone.
Steve and Denise
5,297
14,097
Spalding LINCS
A Class Carthago
Since 2008
Even if it uses double you will have twice the sunshine on your solar so should not be a problem 👍
