Circuit breaker tripping out? (1 Viewer)
hailman
150
12
IoW
Low profile
Lots, on and off, way back to VW splitty`s!
For some unknown reason the circuit breaker is tripping out when plugged into the mains. This has just happened today, sod`s law as I am going away tomorrow! :Angry:.
I have just come back from France where it worked perfectly and is normally on hook up when in storage with no previous problems. I brought the van home today to load up and get the fridge on but as soon as I plugged the hook up cable in the trip went off.
The only thing I have done is to wash the van today. I have looked for traces of water in the hook up socket but it looks as dry as a dry thing.
Any ideas ?
43,329
49,446
assuming you mean the trip in the van.....turn all the other circuits/trips off except the main one then turn each breaker on in turn and see which trips the main RCD.
if it trips with nothing else turned on then get it checked as there is an earth fault between the socket and fuse box.
if you mean the house trip then plug something else in the socket you are using and see if it still trips.
if it doesnt it could be a faulty hookup lead.
unhook from the van and plug the lead into the house socket and see if it trips.
if it does its a faulty lead.
if it doesnt....turn off the main switch in the van, plug into the house socket and the van then turn on the main switch in the van.
it could then be a faulty charger ect causing it to trip.
H
hailman
150
12
IoW
Low profile
It is the trip in the van that is going off.
I made a new lead and it is still the same, trip in house is fine.
When you say `main switch` I assume you mean the switch on the fuse board/control unit ? The van is a Burstner Delphin with the `E control panel` which appears to be working fine.
Simannjo
31
Nottingham.
Hi hailman,
Can you post a photo of fusebox / control panel and all its switches, let us know which is tripping... and we'll go from there.
Sim
H
hailman
150
12
IoW
Low profile
Tried switching off main board in van, so no appliances running and it still sets the trip off. The trip will stay on if there is no supply to the hook up. Still baffled.
Simannjo
31
Nottingham.
Before I can point you in any direction I need to ascertain exactly whats tripping, what you have and where it all is...:Smile:
So...
Is the main switch in the van an RCD? (It'll have a small test button on the front of it)
Is the switch that's tripping the RCD or one of the smaller circuit breakers?
If a circuit breaker, what size is it (in amps i.e B6 B10 B16 B20 etc)
Pics tell a thousand words...
Sim
Jul 28, 2008
813
731
Wiltshire, UK
Ducato Sportivo
Since 2005! 2000+ nights so far...
As per above, more info needed and get back to basics.
I'm just going to add one of my breakers was "buzzing" for a while and tripping for no reason. Turned out the actual MCB had failed. Bought 2x on ebay (1 to fit and 1 as spare) and all okay.
Fortunaltey everything on the fuse when it failed was also powerable by gas. Phew!
scotjimland
2,328
10,096
A Woosh bang
sounds like a faulty RCD main switch in the vans fuse board.
I agree,
to prove, with the EHU cable unplugged from the house supply, disconnect the outgoing pair from the RCD and retry .. If it still trips it's definitely faulty..
scotjimland
2,328
10,096
A Woosh bang
but only if you know what you're doing. !!!!!!
Of course John, but that applies to nearly all the advice given about leccy or gas on any forum ..
Are you saying we shouldn't ?
Of course, you could argue that members wouldn't need to ask if they were competent .. but if they were competent they wouldn't need to ask.. :Doh:
a rock and a hard place comes to mind.
perhaps a stock answer should be
Don't ask if your not sure about what you are doing ..
43,329
49,446
even though its common sense Jim, a timely reminder is always worth a mention.
all too easy to put things back wrongly if you're unsure what you are doing.
gas explodes....leccy bites !
Lenny HB
53,433
150,020
On the coast in West Sussex
Hymer B678 DL
If it is the RCD that is tripping (sounds like it) unplug/disconnect each item that is connected to mains probably the fridge, battery charger & heater then plug each one back in one at a time to find out what is tripping it. Most likley to be the fridge or heater element faulty.
Switching off is not good enough unless you know your switches are double pole an RCD will often still trip if there is a leakage between neutral & earth (it depends how far you are from sub station/transformer & how much neutral is floating above earth).
scotjimland
2,328
10,096
A Woosh bang
Quite so John, no argument there, but do we really want to start another thread on reverse polarity :roflmto:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
whats reverse polarity. is it when the world turns up side down and we become australia?:ROFLMAO:
H
hailman
150
12
IoW
Low profile
Just back from a few days away, including Newbury show on Sunday, so I will investigate further today.
Thanks for the replies so far, if I can`t work it out I will get an electrician ! ::bigsmile:
H
hailman
150
12
IoW
Low profile
Well :Confused:, whilst at Newbury I bought a new hook up socket as mine had gone an awful creamy colour. Fitted that this morning and all systems are A OK.
Not sure if the old unit was faulty, or had got some water in somewhere, or what?
So, panic over!:thanks2:
H
hailman
150
12
IoW
Low profile
Hmmm, need to revive this thread as it has just happened again !
Van has been fine for over a year, sod`s law raises it`s ugly head as I am off to Holland tomorrow to work for 2 weeks. Unhooked the van from my workshop supply where I store it, took across to a mate`s garage to give it a wash, bought it home so I could load my pants and tins of beans, plugged it in to get the fridge working and the bloody trip has gone off again! :Doh:
Only thing I have done is to wash the thing, must be some water getting into a connection somewhere, what do you think?
Not looking forward to 2 weeks with no leccy. :cry:
scotjimland
2,328
10,096
A Woosh bang
I think you are probably correct.. chief suspect is the EHU socket you recently replaced..
H
hailman
150
12
IoW
Low profile
It was over a year ago, it stands out in all weathers, can`t get my head round it.
scotjimland
2,328
10,096
A Woosh bang
I guess the only way to find out is to have it off and check the connections and pins for dampness.
Fridge vents are another common place for water ingress which could drip onto the mains connection on the back of fridge .. especially if you were using a hose for washing.
H
hailman
150
12
IoW
Low profile
Before you replied I had a flash of inspiration and took the fridge vent cover off, there is a 2 pin euro type plug sitting just behind the vent for the mains to the fridge. Took the plug out and it was wet through :RollEyes:. Well done Burstner, great place for a plug :Doh:
All sorted now, thanks for the replies. :thumb:
I will sort out a more permanent solution when I get back from my trip.
