Catalytic converter theft (2 Viewers)
ebo
Nov 9, 2009
98
105
Essex
A class Carado i449
Since 2009
Hi all, This is my first post so bear with me. I have recently suffered the second theft of a catalytic converter from my motorhome ( Fiat X250 based ) in just over a year, the first was whilst it was in so called secure storage along with fourteen others in one night, on that occasion the whole thing was unbolted and removed, and again within the last month whilst parked on my drive outside my house, this time the catalytic converter was unbolted from the downpipe (just three nuts) and then cut along the pipe by using a chain cutter, in a similar way a plumber would cut a length of pipe, needless to say it doesn't make any noise, which is probably why I didn't hear anything even though I was sleeping no more than five feet away in a downstairs bedroom.
Has anybody got any idea how to prevent this happening, I've looked at the Catclamp and Catlok on the internet, but they are just cables that could be bolt cropped, the Police unofficially suggested wiring it up to the mains!!! as much as I'd like to its not really an option.
Any thoughts would be appreciated.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
unfortunately i don't think there is a solution other than to remove it and put on just for the MOT then remove it again.
i suppose if they crawl under the van and see just a straight bit of pipe where the cat should be then they will move on to the next target.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
The theory is that its more effort than it is worth
Link Removed
ebo
ebo
Nov 9, 2009
98
105
Essex
A class Carado i449
Since 2009
Does that not effect the running of the engine.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
to be perfectly honest you would probably get an increase in power and a reduction in fuel consumption as the engine will breath better.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
I can't give any details as yet but one of my suppliers told me only today that they are working on a solution to cat thefts, watch this space as they say.
D.
Rayb182
Nov 13, 2009
1,523
2,223
Great Bentley
Sundance 590 PR
Since 1999
Before we came away , the yard where we store our van was broken into had the same problem, the only reason they didnt get our catalytic converter was the bolts had rusted on and they wanted to get in and out without problems as such as ours, now the owner has had to wrap razor wire around the catalytic converter.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
i must admit if i found one of these thieves under my van i would make sure they didn't come out from under the wheels.
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I think at the moment, the only real answers are to remove as mentioned elsewhere, or actually have a big plate attached to the underside of the van so the cat is between the floor and the plate
gozomike
Funster Life Member
1,001
863
Warwickshire - sometimes - but not often
Wildax Constellation
Since August 2008
I wonder for those who drive straight into their parking position if it might be possible to build up the ground on the two sides and one end of the van, maybe with a low wall, making it difficult or impossible to get underneath.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
you mean like parking on a speed hump with wheels either side:thumb::thumb::thumb:
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
...................or park over a deep snake pit with spikes :thumb:
gozomike
Funster Life Member
1,001
863
Since August 2008
Might work, what I was thinking of would be more like parking between two or better still building a low wall either side of the van so it was still possible to open the doors but not get underneath. In most cases I would think it would be less than a foot high.
43,329
49,444
i agree.......the chances of being roadside tested are far less than getting it stolen.
you will need to have fabricated a section of correct bore and shape pipe to replace it.
we managed for a long time without them, 'til the 'save the planet' anorak's decided we need them.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Sadly I think the only measure which will stop the metal thieves is summary execution!
Might be an idea for one of those Government e-petitions!::bigsmile:
ppsontour
9
north kent
low profile
Newbie
I have fitted an Armacat onto my van this morning as there seems to be an increase of thefts in our area.
darklord
1,241
1,230
essex
coachbuilt
three years
Unless you can order an airstrike on the two nearest Itinerant sites, take the bleddy thing off, fit a replacement pipe, and do a swap back when you do the checks for MOT time. The cost of the replacement pipe will be offset by the new life of a hardly used cat, weve been removing the centre boxes and cats of landrovers for ages, no-one been nicked so far to my knowledge, and your engine, as said, wont be breathing in its own farts.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
i think theres a lot of insider information going on with this.
there seems to be a new product appear in the area just after a spate of thefts.
a bit like the thinking that the people that write anti-virus software actually send out the virus first.
Sep 4, 2011
2,664
6,754
No more
I like the idea of bolting a metal plate to the chassis so the cat converter/particulate filter is in between:thumb: Catlock dont make anything to fit round our particulate filter.
tommy_transit
17
5
north east
renault trafic
im a newbie
if your vehicle is diesel the cat does not get tested for your mot, its only a smoke density test done with a smoke meter, so if yours runs ok without it then leave it off, petrol ones do have a cat test so put it back on for your mot, :thumb:
buyer
Funster - Life Member
218
74
leicestershire
american coach
20 plus another 12years tugging/small campers
fully agree with tommy transit
:thumb:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Broken Link Removed
Broken Link Removed
the dedcat pipe looks like this
pamella
146
39
walsall, west mids
c class?
any new ideas on cat theft?
we had ours taken from our car on friday.we are looking at the catlok and i wondered about alarms that detect motion nearby or have a tilt sensor?
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Another solution I have seen is to have a raised area... In this case the guy made a large wooden platform that his wheels went either side of.. It left the ground clearance under his small van negligible..
Quite clever I thought.
Apr 28, 2013
3,682
80,852
Alentejo,Portugal
Hymer A Class
Since the '80,s
Aba,due to an injury my year 2000 Chausson Welcome sat in the yard for a year.It ran fine on the last trip before layup.
When it was due a CT,2 year MOT in France it ran so rough.I tried an Italian tune up,flat out everywhere but no good.
My local French dealer towed it to the garage and said I needed a new cat,€1200:cry:
I looked at the fiche with him and it was on the cusp of the first Cat models,€1200 for the cat,€120 for the straight pipe.
I said fit the pipe,ran it for an hour before test and it passed with low emissions, cheap fix,leave it off and take a chance.Good luck.:thumb:
Goes better than ever and 200kms per tank more economic!!!
TheBig1
17,630
43,277
get a local fabricator to make a shaped guard plate that bolts over the cat. just make sure you leave room round it to prevent vibration and heat buildup
daisy mae
675
597
Leicestershire
C class Coachbuilt
I`m a newbie, now 1 year
When I can I will have my cat removed and have a straight pipe, will still be ok for the mot with the straight pipe as I have checked.
