oh: hi just bought an 08 2.3 fiat with 12000 miles and i am going to have a new cambelt fitted but garage wants to fit a new water pump also,is this correct !!!!!!!!!!!!!! oh:
the reason why it is reccomended that water pumps are changed along with some cambelts, is that the toothed pulley on the pump forms part of the cambelt set up [along with tensioner wheels and diesel fuel pump sprocket] if you dont change it you run the risk of the water pump center bearing failing due to the tension which the new timing belt puts on it ! if it does, then virtually the whole job has to be done again to replace the failed and[ usually by then] leaking water pump ! like most things in life its a case of is it worth not changing when they can cost as little as ÂŁ10 trade !!! regards garry
if its a ducato your garage was lying to you.Replaced timing belt on my 07 2.3 last week and was going to do the water pump aswell but garage said on mine it was easy to get at so could be done fairly easily by its self
recomendation for cambelt change is 5 years or 60,000 miles, whicheveroh: hi just bought an 08 2.3 fiat with 12000 miles and i am going to have a new cambelt fitted but garage wants to fit a new water pump also,is this correct !!!!!!!!!!!!!! oh:
if the water pump isn't leaking then why change it.
cambelts are scheduled for change every 60,000 miles or every 5 yearsoh: hi just bought an 08 2.3 fiat with 12000 miles and i am going to have a new cambelt fitted but garage wants to fit a new water pump also,is this correct !!!!!!!!!!!!!! oh:
