cambelt change
Discussion in 'Tech/Mech General' started by jandv, Apr 28, 2013.
  1. jandv
    jandv Read Only Funster
    Nov 26, 2009
    62
    12
    spain
    :Doh: hi just bought an 08 2.3 fiat with 12000 miles and i am going to have a new cambelt fitted but garage wants to fit a new water pump also,is this correct !!!!!!!!!!!!!! :Doh:
  2. dshague
    dshague Funster
    Aug 22, 2007
    921
    188
    sth yorks
    my garage said the same ,wile you have the engine stripped down check pulley and water pump fit new ...cost pump ,pulley and timing belt £300.
  3. brynric
    brynric Funster
    Sep 5, 2009
    340
    316
    Worcestershire
    My Garage always recommends this. They renew relatively cheap bits when the bigger job is stripped down. I'm due a cam belt change on my '07 Ducato soon and I'll check the other bits have been done.
  4. camocam1
    camocam1 Read Only Funster
    Aug 28, 2012
    1,112
    783
    Elgin,Moray,Scotland
    Replaced timing belt on my 07 2.3 last week and was going to do the water pump aswell but garage said on mine it was easy to get at so could be done fairly easily by its self
  5. greyman1
    greyman1 Read Only Funster
    Aug 7, 2011
    363
    273
    manchester
    the reason why it is reccomended that water pumps are changed along with some cambelts, is that the toothed pulley on the pump forms part of the cambelt set up [along with tensioner wheels and diesel fuel pump sprocket] if you dont change it you run the risk of the water pump center bearing failing due to the tension which the new timing belt puts on it ! if it does, then virtually the whole job has to be done again to replace the failed and[ usually by then] leaking water pump ! like most things in life its a case of is it worth not changing when they can cost as little as £10 trade !!! regards garry
  6. Larby
    Larby Funster
    Jun 17, 2012
    1,821
    4,171
    North Essex
    Incredible as it may seem, your garage was trying to save you money and hassle long term.
    I endorse what greyman says above. My son has a garage and some people want just a cam-belt and wont pay for a tensioner and pulley set.
    And look what can happen to a worn and brittle tensioner. This engine was about to let go, it came in for an MOT and we were drawn to the cam-belt area and saw the broken bit bouncing around !
    [​IMG]
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    if its a ducato your garage was lying to you.
    to change the pump means the same amount of work as changing the belt.
    the pump is driven by the cam belt and it needs to come off to change the pump.
    for an extra 20 minutes work and maybe £30 for a pump its false economy not to swap out the pump at belt change.
  8. chaser
    chaser Funster
    Feb 16, 2013
    8,009
    9,069
    uttoxeter
    I have an 07 pug 2.2 with a chain, so when does the pump want doing on that, or is it on the fanbelt where they always were and still should be, just haven't looked as I know I should but saw this thread so wondered, thanks
  9. greyman1
    Aug 7, 2011
    363
    273
    manchester
    in general, if a water pump is run via the fan belt [as in a chain drive engine]and therefore does not form part of the cambelt drive, then in theory it should not need replacing unless it becomes faulty or leaks but in reality it is sometimes prudent to replace them if you have to fit a new fan belt or auto tensioner, [for the very same reasons as with the cambelt. it is the retensioning of parts that have gradually settled in and worn together over time that usually causes the problems !!] regards garry
  10. trackar
    trackar Read Only Funster
    Apr 29, 2013
    3
    north staffs
    no need just yet
    recomendation for cambelt change is 5 years or 60,000 miles, whichever
    comes first.
    if the water pump isn't leaking then why change it.
  11. hilldweller
    Dec 5, 2008
    27,771
    26,860
    Macclesfield
    Read the persuasive arguments above.
    We didn't the first time, next time we will.
    Which I guess, because we haven't had a pump problem, sort of confirms your remark.
  12. trackar
    Apr 29, 2013
    3
    north staffs
    no need to change
    cambelts are scheduled for change every 60,000 miles or every 5 years
    whichever occurs first.
    If the water pump isn't leaking then why change it.
