Awning woes (1 Viewer)
Sep 5, 2008
566
332
York
C Class Bessacarr 769
Since July 2010
Why if something is going to go wrong, does it wait until you are at the other side of the water !
The fiamma awning winding mechanism has failed. Took it to a fiat dealer who said they could fix it. They ordered the part and we went there yesterday to find he can't do it after all. Apparently it needs someone who does bodywork to fix it as they can't get into it. So here we are on the mosel with a spare part and no awning. :Doh:
lindylou
Sep 5, 2008
566
332
York
Since July 2010
Problem is, on the Bessacarr the awning is built into the side of the van and they can't access the parts without taking the whole thing out. Stupid system.
bobandjanie
8,166
15,813
Javea, Spain
Pilote V600g
I'm sure a motorhome dealer will sort you out, awnings have very little holding them on, :winky: in fact I saw someone at Stratford Show one year and his awning was falling off :Doh: that was built into the motorhome and the base plate behind the awning was held on the side by a few self tapping screws. :whatthe: Bob.
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
Look inside the top cupboards, you may see a little white covers with bolts underneath.
Usually x3 lots in different cupboards.
It will need 2 or 3 people to help to hold/unbolt it and refix it :Eeek:
Maybe a chance for intercontinental relations to grow on site-- buy them some wine and ask for a lift :thumb:
Wickolad
490
542
Wickersley
Have a look inside the overhead lockers, behind the awning, there should be 3 or 4 depending on length, plastic trims that should be easily removed that expose the securing bolts/plates. One each end and one or two evenly spaced between these. As far as I know, removing the nuts and plates will release the awning from the housing, just ensure it's supported whilst removing the fixings, this should then facilitate access to the mechanism.
There may be some funsters that could offer more details for your particular Motorhome, but it's worth a look to see if it's the same fitting system. I'll check mine again when back home to see if there's anything I could add to the above.
Wickolad
490
542
Wickersley
Sorry joner8888, I wasn't copying, just taking too long typing on phone between bank and supermarket..... Whilst parked up of course waiting for htmbo. I fully agree with you though, sound advice.:thumb::thumb:
Oct 1, 2013
7,513
19,955
Lanzarote
Nil by mouth
Lots
lindylou
Sep 5, 2008
566
332
York
Since July 2010
Thanks for that advise all. Will see if we can find a dealer who can fix it.
Lin
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Hi,
As most people have already said, the nuts and plates behind the white caps need to be removed. On your motorhome there will be at least 5 of them. Thats provided Swift haven't hidden any of them behind a false wall. The awning will need some brute force to remove as swift bond the brackets on. We usually have at least 4 fitters working together to remove it. A bar and sharp blade are a must.
Good Luck:thumb:
Any further help please feel free to call
Ian, Workshops
01580 881288
www.johnscross.co.uk
