Awning woes
Discussion in 'Continental Touring' started by lindylou, May 1, 2014.
  1. lindylou
    lindylou Funster
    Sep 5, 2008
    443
    218
    York
    Why if something is going to go wrong, does it wait until you are at the other side of the water !
    The fiamma awning winding mechanism has failed. Took it to a fiat dealer who said they could fix it. They ordered the part and we went there yesterday to find he can't do it after all. Apparently it needs someone who does bodywork to fix it as they can't get into it. So here we are on the mosel with a spare part and no awning. :Doh:
  2. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,447
    2,540
    UK / Spain
  3. lindylou
    lindylou Funster
    Sep 5, 2008
    443
    218
    York
    Problem is, on the Bessacarr the awning is built into the side of the van and they can't access the parts without taking the whole thing out. Stupid system.
  4. bobandjanie
    Apr 28, 2008
    4,447
    2,540
    UK / Spain
    I'm sure a motorhome dealer will sort you out, awnings have very little holding them on, :Wink: in fact I saw someone at Stratford Show one year and his awning was falling off :Doh: that was built into the motorhome and the base plate behind the awning was held on the side by a few self tapping screws. :Eek!: Bob.
  5. joner8888
    joner8888 Read Only Funster
    Jan 4, 2012
    2,190
    1,971
    somerset
    Look inside the top cupboards, you may see a little white covers with bolts underneath.
    Usually x3 lots in different cupboards.
    It will need 2 or 3 people to help to hold/unbolt it and refix it :Eeek:
    Maybe a chance for intercontinental relations to grow on site-- buy them some wine and ask for a lift :thumb:
    • Like Like x 1
  6. Wickolad
    Wickolad Funster
    Sep 10, 2013
    480
    518
    Wickersley
    Have a look inside the overhead lockers, behind the awning, there should be 3 or 4 depending on length, plastic trims that should be easily removed that expose the securing bolts/plates. One each end and one or two evenly spaced between these. As far as I know, removing the nuts and plates will release the awning from the housing, just ensure it's supported whilst removing the fixings, this should then facilitate access to the mechanism.
    There may be some funsters that could offer more details for your particular Motorhome, but it's worth a look to see if it's the same fitting system. I'll check mine again when back home to see if there's anything I could add to the above.
  7. Wickolad
    Wickolad Funster
    Sep 10, 2013
    480
    518
    Wickersley
    Sorry joner8888, I wasn't copying, just taking too long typing on phone between bank and supermarket..... Whilst parked up of course waiting for htmbo. I fully agree with you though, sound advice.:thumb::thumb:
  8. Yorick
    Yorick Funster
    Oct 1, 2013
    4,002
    5,875
    Lanzarote
  9. lindylou
    lindylou Funster
    Sep 5, 2008
    443
    218
    York
    Thanks for that advise all. Will see if we can find a dealer who can fix it.
    Lin
  10. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,265
    5,250
    East Sussex 01-580-881288
    Hi,
    As most people have already said, the nuts and plates behind the white caps need to be removed. On your motorhome there will be at least 5 of them. Thats provided Swift haven't hidden any of them behind a false wall. The awning will need some brute force to remove as swift bond the brackets on. We usually have at least 4 fitters working together to remove it. A bar and sharp blade are a must.
    Good Luck:thumb:
    Any further help please feel free to call
    Ian, Workshops
    01580 881288
    www.johnscross.co.uk
