are you just sticking it and not screwing it as well???
I have done the same to my van.
. However the first time I tried to fit the awning I found that the rail pulled open and the awning came out. I had to take it off and fit Aluminium.
Hope this helps
Lunarman
DO NOT use the plastic rail. I fitted it first because it was white and I thought it would look better on the van. However the first time I tried to fit the awning I found that the rail pulled open and the awning came out. I had to take it off and fit Aluminium.
Hope this helps
Lunarman
See this post by @scotjimlandI want to fit c section awning rail as above and no screws just sikaflex but where's the best place to get the rail that's my problem re online it comes in 3 pieces to make the length ie maybe 3 X 1.2 Mtrs , 1 length would be better but I think would not survive the courier transport
Any ideas
Any ideas
Thanks for that
I will have to get in 3 sections and intend using Sikaflex will have to get the 2 joints well lined up though
Thanks again
Just a thought..... For others too...
My Moho has graphics ... If just stuck with Silka ( and no screws ) would that not just pull the graphics off .. As opposed to being glued directly to the aluminium panel?..
I'm not sure if our 2014 Auto Sleeper body panels are strong enough,as the fibre glass panels are so thin.
John.
If you have got a wind out awning fix it to the bottom of that you can glue and screw or pop rivet it saving messing up the side of your van.
I pop riveted ours to the underside works a treat
Unless the graphic was the full length of the rail I wouldn't be worried. If unsure use a few self tapping screws where the graphic is..
It is... That's why I mentioned it
how was I to know that.. you said 'graphics' not graphic.. I took that to be plural.. so not a one piece graphic the full length
besides, I was only trying to be helpful..
