autotrail apache water igress/ damp (2 Viewers)
shakeytits
13
10
west yorkshire
just looking to buy
My 2008 700se apache has bad damp in front habitation area under front seat and side of cushion ( mould ) anyone had any issues. Thanks
rolandrat
436
258
Lancashire
Hi Top
I've owned 3 Autotrails, the 03 on a Merc chassis was perfect in every way. Then I bought a brand new 09 on a Fiat chassis which was a sponge on wheels then an 11 reg which was even worse. The water ingress should never have happened and there were many other problems all caused by poor quality control management. I might add that the later models have a different design of skirt which is very flimsy. In the past they were known as a premium well built motorhome but because of my experience my view of their products leave much to be desired.
tonka
10,834
21,544
Cannock, Staffs
A class Burstner 800
Since 2000
I did post earlier from my ipad BUT it seems to have dissapeared ???
Have heard mention of a few Autotrails with ingress problems around the windows, also some where the outer sides started to crack on the corners..
[ame="https://www.youtube.com/watch?v=ObHXPnTtMho"]AUTOTRAIL APACHE 700 SE 2008 WATER INGRESS - YouTube[/ame]
S
shakeytits
13
10
west yorkshire
just looking to buy
water ingress.
I've owned 3 Autotrails, the 03 on a Merc chassis was perfect in every way. Then I bought a brand new 09 on a Fiat chassis which was a sponge on wheels then an 11 reg which was even worse. The water ingress should never have happened and there were many other problems all caused by poor quality control management. I might add that the later models have a different design of skirt which is very flimsy. In the past they were known as a premium well built motorhome but because of my experience my view of their products leave much to be desired.[/QUOTE .after some research it seems that there was a problem with the front windows in the habitation area.they seem to leak when raining and the water runs down the inner panel and forms a pool under the seat behind the drivers seat. Lets hope it is not going to be a costly repair
grumps147
1,840
2,448
St.Helens
Between
Last year our 2010 developed a dinette window leak with identical symptoms,largely due to not using it and not discovering it quickly. We have so far had 3 of our windows resealed because of leaks.
S
shakeytits
13
10
west yorkshire
just looking to buy
water ingress.
Yep seems to be a problem as this motorhome has been stood for some time. It only seems to be the front dinette window.i think I will have a go at sealing it myself..has anyone done this or is it a dealer issue.
PAGR
86
155
Camberley
Autotrail Arapaho
We had exactly the same problem with our 2008 Arapaho last year. Took the window out surprisingly easily as we found the sealant was originally on the frame but was too low at the top to meet the body. We had changed the angle at which it is parked up and water was finding a new route down the side.
Cleaned it all up, resealed, and no problems since. Also resealed the capping behind the drivers door at the same time as I thought that may have been letting water in.
Ran a dehumidifier focused on the damp patch for a while after.
Scout
3,959
121,379
South Yorkshire
chic c line
Ive never had a problem with damp but there must have been one at sometime before I owned my van around the rear top l think it was caused by the screws holding the top of the ladder there now seems an excess of sealant over them which looks like a warraty repair. I had some cracking of the sealant on the joints around the van and I saw the same on loads of vans. I had it completely y resealed professional ly by uk campers lincoln Allthough it could be diy job if you have the time and the skills
Steve304
39
7
Wigan
2 Years (12000 Miles)
This is very unusual for a Motorhome of this vintage, more to be expected on older vans. Especially those which have been subjected to extreme weather differences over time, i.e. hot summers abroad then cold winters at home.
Good news is it should be a relatively simple fix, but if it's still under warranty, get your dealer to sort it out. This might help to show how it's put together? Broken Link Removed
Steve
PS Great username by the way:Smile:
S
shakeytits
13
10
west yorkshire
just looking to buy
water ingress
cheers steve, looks pretty straight forward, as i dont need to strip the window just seperate the inner and outer frames and fit some new sealing compound, so now lets wait for a dry day ? lol
