Has anyone heard anything about the new 8 speed auto gear box on the fiat Ducato
That's clever as its not in production yet.Nothing bad, mine is an absolute dream after the comformatic......
Early adopterThat's clever as its not in production yet.
Obvious I have a new MH, I donĀ“t even know how many gears it has.......That's clever as its not in production yet.
Test pilot...fair playNothing bad, mine is an absolute dream after the comformatic......
Take it back. You've got one missing.Nothing bad, mine is an absolute dream after the comformatic......
2035 is 11 years away and that's for cars I think commercial vehicles will be excluded. Keep up boy.Whatās the point of all these new diesel vans when weāre supposed to be all electric in 6yrsā¦
Likewise, 8 gears 9 gears I just lose count! I have 9 on the Fiat Van I think anyway it's superb.Obvious I have a new MH, I donĀ“t even know how many gears it has.......
Because its not 6 years yet and everyone will be desperate to buy one before it is.Whatās the point of all these new diesel vans when weāre supposed to be all electric in 6yrsā¦
What's 6 years got to do with it?Because its not 6 years yet and everyone will be desperate to buy one before it is.
Good idea, it is under warrantyTake it back. You've got one missing.
In the rapidly growing past, I remember 3 speed autos and 4 speed manuals with first being non-syncro and so low geared that you always started in second, effectively a 3 speed manual.......happy days..and I agree, auto is the way, unless its a lightweight soft top with a few winding roads and passes to chuck it around...Likewise, 8 gears 9 gears I just lose count! I have 9 on the Fiat Van I think anyway it's superb.
8 gears on the Volvo and that has been superb as well. Manual boxes are so yesterday!
Ooh, I must try that.....On US RV sites there has been much discussion/complaint that the 9-speed gearbox is designed for all Fiat's from cars to the Ducatto/RAM Promaster but installers just block out the top two gears so it is a de facto 7-speed gearbox (the top 2 gears don't have enough torque for a full 4,000 kg van).
Maybe Fiat are just being honest and keeping the gearbox the same but removing the top gear for all vans.
If you have a 9-speed does it use the top 2 gears (use the manual override, can you get the rev reduction of the higher gears above 7? I tried this on a US van and it does stop at 7, can't access 8th, or 9th, gear).
I'd be interested to know what rpm you get in 7th, 8th, 9th at, say, 65mph, if anyone knows. No rush, just curious.Mine def uses all 9 gears....
I have the 9-speed box and it's brilliant. On motorways it's in 8 or 9 all the time cruising between 60 and 70, occasionally down to 7th gear if it's a steeper incline.If you have a 9-speed does it use the top 2 gears (use the manual override, can you get the rev reduction of the higher gears above 7? I tried this on a US van and it does stop at 7, can't access 8th, or 9th, gear).
I find our 6-speed Fiat based MH reminds me of 'those days'. 1st is really low and 6th is really high, so it feels like a 4-speed 'box plus a crawler gear and overdrive.In the rapidly growing past, I remember 3 speed autos and 4 speed manuals with first being non-syncro and so low geared that you always started in second, effectively a 3 speed manual.......happy days..and I agree, auto is the way, unless its a lightweight soft top with a few winding roads and passes to chuck it
You forgot double de-clutching!In the rapidly growing past, I remember 3 speed autos and 4 speed manuals with first being non-syncro and so low geared that you always started in second, effectively a 3 speed manual.......happy days..and I agree, auto is the way, unless its a lightweight soft top with a few winding roads and passes to chuck it around...
It means they can tune the engine to be really efficient in specific rev bands. As long as it changes fast and seamlessly, give it however many it needs.My car has 7 gears so maybe 9 on a commercial vehicle is overkill?
I think it's unlikely the installers play with the ECU. If there's not enough torque to maintain the requested power a higher gear, it won't change up. The gearboxes should manage it themselves, so the converters shouldn't need to alter anything anyway. But it should still go to 9th when coasting at high speed.On US RV sites there has been much discussion/complaint that the 9-speed gearbox is designed for all Fiat's from cars to the Ducatto/RAM Promaster but installers just block out the top two gears
I like it too, but I did notice that if you use the limiter and keep your foot to the floor, it will stay in 8th, you need to lift a little then it drops into 9th.....not so comfortable to use as the old cruise control, that was set and forget, the limiter requires more throttle action.I have the 9-speed box and it's brilliant. On motorways it's in 8 or 9 all the time cruising between 60 and 70, occasionally down to 7th gear if it's a steeper incline.
If I'm going downhill or I'm already rolling and I'm not in a hurry, I'll often start in 2nd. I can still lift the clutch pretty much straight away.I find our 6-speed Fiat based MH reminds me of 'those days'. 1st is really low and 6th is really high, so it feels like a 4-speed 'box plus a crawler gear and overdrive.
