400 watts @110volts = ? amps @240 Volts. (1 Viewer)
zaskar
1,159
371
5th Wheel
Title says it all (hopefully!:roflmto:)
Basically, there is a HOTROD available for the Atwood/Suburban water heaters which uses 400 watts at 110Volts.
What I'd like to know is, when I'm on a 240Volt hook up, how many of my precious 10amps is that gonna use?:Eeek:
p.s Being sad (and bored at work!) I'd appreciate seeing the relevant formulae.
I tried Google and confused the hell out of myself!:ROFLMAO:
Ta:thumb:
2,347
10,193
400 watt is the power, dived by the voltage for the amps..
ie watts = Volts x Amps
your answer is, less than 2 A on 230v
Posted via Mobile Device
zaskar
zaskar
1,159
371
5th Wheel
Ah!::bigsmile: Thanks Jim. I thought it would be more complicated than that.:Doh:
2,347
10,193
Don't worry, someone will be along soon to complicate it :)
how many motorhomers to change a light bulb ?
American Dream
156
Lincoln
[Hi
/QUOTE]
Meeeeeeee
The calculation is correct but.....Won't doubling the voltage to it blow the element?
Just a thought.
It's like applying 24v to a 12v light bulb.I bought a site transformer to bring the voltage down for just that reason.
zaskar
zaskar
1,159
371
5th Wheel
[Hi
If I was doing that, you'd be right.:Smile:
But I wont be. The element will be run via a 110volt step down tranny.::bigsmile:
All I needed to know was how much of my precious 240 that would equate to.
Fulltiming on a 10amp supply can be made sooooooo much easier if you take the time to learn the power consumptions of your equipment so that you get to know what you can and cant run at the same time.:thumb:
American Dream
156
Lincoln
Aaah Right,
I'm using a step-down in much the same way although not continuously.:thumb:
S
stagman
Ta:thumb:
You probabally will need a 240v to 110v transformer that can handle at least 6amp on the secondary side i.e the 110v side :thumb:
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Pedantry
400w @ 110v = 3.6?????? amps 400w @ 220V = 1.81???amps
400w @ 240V = 1.66??amps
A 2:1 step transformer with primary pd 240vAC will produce 120vAC (ignoring losses) Good quality transformers will have several "tappings" allowing selection of an output voltage nearest to your requirement.
The "hot-rod" will cope with just about anything from 100 to 130v.
Don`t forget to specify the Frequency rating, its not particularly critical BUT a transformer is designed for use on a certain frequency and "Off Frequency" can sometimes produce an anoying "humm" or "buzz". "overspec" can be expensive and a 5 to 6 amp rating on the secondary side, as suggested, will be more than adequate, you MAY even have one on board IF you are still using the American spec; Microwave etc? If so check its rating as it may be capable of taking the hot-rod as well?
Pete
