400 watts @110volts = ? amps @240 Volts.
Discussion in 'Motorhome Chat' started by zaskar, Dec 10, 2008.
  1. zaskar
    zaskar Funster
    Sep 25, 2007
    988
    98
    UK
    Title says it all (hopefully!:Laughing:)
    Basically, there is a HOTROD available for the Atwood/Suburban water heaters which uses 400 watts at 110Volts.
    What I'd like to know is, when I'm on a 240Volt hook up, how many of my precious 10amps is that gonna use?:Eeek:
    p.s Being sad (and bored at work!) I'd appreciate seeing the relevant formulae.
    I tried Google and confused the hell out of myself!:Rofl1:
    Ta:thumb:
  2. scotjimland
    Jul 25, 2007
    28,934
    25,601
    400 watt is the power, dived by the voltage for the amps..
    ie watts = Volts x Amps
    your answer is, less than 2 A on 230v
    Posted via Mobile Device
  3. zaskar
    zaskar Funster
    Sep 25, 2007
    988
    98
    UK
    Ah!:BigGrin: Thanks Jim. I thought it would be more complicated than that.:Doh:
  4. scotjimland
    Jul 25, 2007
    28,934
    25,601
    Don't worry, someone will be along soon to complicate it :)
    how many motorhomers to change a light bulb ?
  5. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
  6. zaskar
    zaskar Funster
    Sep 25, 2007
    988
    98
    UK
  7. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
  8. stagman
    stagman Deleted User
    You probabally will need a 240v to 110v transformer that can handle at least 6amp on the secondary side i.e the 110v side :thumb:
  9. PeteH
    PeteH Funster
    Nov 22, 2007
    2,084
    2,620
    East Yorkshire
    Pedantry
    400w @ 110v = 3.6?????? amps 400w @ 220V = 1.81???amps
    400w @ 240V = 1.66??amps
    A 2:1 step transformer with primary pd 240vAC will produce 120vAC (ignoring losses) Good quality transformers will have several "tappings" allowing selection of an output voltage nearest to your requirement.
    The "hot-rod" will cope with just about anything from 100 to 130v.
    Don`t forget to specify the Frequency rating, its not particularly critical BUT a transformer is designed for use on a certain frequency and "Off Frequency" can sometimes produce an anoying "humm" or "buzz". "overspec" can be expensive and a 5 to 6 amp rating on the secondary side, as suggested, will be more than adequate, you MAY even have one on board IF you are still using the American spec; Microwave etc? If so check its rating as it may be capable of taking the hot-rod as well?
    Pete
