Lenny HB
- Oct 18, 2007
- 53,431
- 150,019
- Hymer B678 DL
44 amp charge? was that from the alternator as an Electroblock can't produce that but you did say it may have a different charger. Gel's when fairly flat have a lower internal resistance than wet cells so can take a very high charge rate enough sometimes to destroy themselves. On my last van I have seen 44 amps going in from the alternator.
Note: just looked at the pic that's not an Elektroblock, it is a Reich e-Box they were fitted to other vans in the Hymer group so probably is an original fitting. Some info here.
You say that on charge they were reading 13.7v but have they been fully charged. Now you have had a load on the batteries you need to monitor the charging. The voltage should rise to 14.2 - 14.4 volts and then stay at that for 8 hours then reduce to 13.8v. If the voltage drops to 13.8 after one hour the charger is set to wet cell and the batteries will one get an 80% charge.
Once you have established that if things still not right you need to separate the batteries and run the tests on each one.
You really need to disconnect the solar or do the tests in the dark as once you have turned off the load even the smallest output from the solar will give a false high reading.
