Yet another DAB thread
Kb36
Coach built
Since 2019
This has probably been asked hundreds of times, I tried searching for a solution but got bogged down.
I have an elddis 115 on a Peugeot boxer base but my dab reception is shocking, is there an easy way to improve this?
Fit a decent aerial, preferably a roof mount one and mount it on a ground plane. Expect to pay around £75 for a decent one.
I think Lenny has probably got the right answer.
Our PVC came with a dab radio installed - no idea if by Fiat or RAPIDO (the converter) - but it's got a proper aerial mounted on the cab, high above the windscreen. Radio works a treat and never get any interference on dab.
Hope you can get yours sorted.
I fitted a small pencil sized DAB aerial stuck on the windscreen.
As expected not brilliant reception but ok with a good signal.
I found fitting the internal night/sun screens improved reception markedly ?
Ours is a small whip on the roof does DAB, FM & TV with different amps works a treat, it's a Hymer standard fit.
worked for me
Had a screen one on my last van that came with my Clarion stereo, it worked quite well but nowhere as well as good the roof mounted one on the current van.
