gerry mcg
Apologies for the long post, but I’m looking for a bit of assistance wiring my Votronic VCC1212-50 B2B via my EBL119.
ive had some electrical gremlins since it was wired by my local auto electrician, and ive removed it until i can get to the bottom of things.
i have an EBL119, so if i understand correctly, i can wire the 50A B2B through the EBL and utilise the Split charge system in the EBL. Am i correct in saying the EBL has an “internal” split charge relay, as in it is inside the EBL? (Out of interest, if i wanted to wire the B2B directly to the leisure battery, how would i disable the EBL split charge relay?)
i’m attempting to wire the B2B as per this configuration.
I have fitted
the question relates to wiring main battery cables to the VCC1212-50 and EBL.
my EBL has the following cables,
My question is how to wire the B2B into the loop.
my understanding is
Do i move one / both of the pair from the EBL to the B2B? Or add another to the system? This is the bit that is not clear. If i understand teh B2B wiring diagram, i do not need to deal with the small relay circuit to the right og the diagram.
With the B2B set to 14.4v Lithium profile, am i correct to expecting the voltage across the B2B “IN Start +” and “12v Comm -” terminals to be the alternator voltage (say 13.7v with the engine running?
and the voltage across “12V Comm -“ and “OUT Bord +” B2B terminals to be 14.4V (and no higher)?
and the voltage across the EBL “Start In +” and -ive terminal should be 14.4V (as that is what is incoming) and the Voltage across the EBL”-ive” and Black Leisure out should be whatever the leisure battery voltage is at at the time (same as what the BMV shunt reports?)
I have fitted
- a D+ wire,
- a fused Vs+and Vs- paired wire direct from the starter battery terminals;
- a fused Bv+ and Vb- paired wire Direct from the leisure battery terminals; and
- a temp sensor wired direct to the -ive terminal post of the lithium battery
- a red “Starter battery +ive input” on the left which is fused to a 50A maxi fuse in the under floor starter battery box
- 2x brown ”common ground” -ive wires in the central terminal, and a
- single Black leisure battery +ive output
my understanding is
- the red “Starter battery +ive input” which was on the left terminal of the EBL (which is fused to a 50A maxi fuse in the under floor starter battery box) should be wired to the left (IN START) terminal of the B2B, and
- i should add a red “Starter battery +ive output from the right (OUT BORD) terminal of the B2B to the “Starter battery +ive input” terminal of the EBL.
