Hi Markus and welcome to the forumHi new to motor homing what should I do about winter storage draining system etc should I leave motor home plugged in or disconnect battery’s have autotrail eks many thank Mark also going away for 5 weeks and leaving
Thanks a lot sounds good will doI leave mine plugged in. Drain water, waste, cassette, and have tiny heater with a frost stat inside - or I did. Now leave Alde set at 8 degrees.
thanks a lot will doHi Markus and welcome to the forum
Drain down all the water, leave the taps open and try to get the residual water out of the pipes and pump ( you can actually buy a small kit that will help with this )
If you are leaving it on hook up leave the batteries connected... No point in having it plugged in if you disconnect the batteries !
