Winter Covers
Autotrail Tracker RS
I’m a newbie
Hi, I have a Autotrail Tracker RS 2013 and need a set of winter covers for it. Can anyone help with what i need to purchase please? Thnaks in advance
If you mean windscreen covers then have a read here https://www.motorhomefun.co.uk/foru...-thermal-screens-4-brands-to-consider.196105/ - we currently have Minster Polar ones & they are good quality & well priced.
Motorhome covers are best described as a bit Marmite on here however if used on a freshly washed motorhome & secured well then the Maypole ones are excellent & affordable https://www.motorhomefun.co.uk/forum/threads/winter-covers-for-motor-homes.180115/#post-2934348 & generally last around 3 years. Specialised Covers -Broken Link Removed- are a popular but much more expensive option.
Searching on the forum will bring up lots of info. but sure others will be along to post on here shortly to help too :)
Hi Wombles i do need a windscreen cover but am after fridge vent covers in first instance
Aah - didn't think of those! We have a compressor fridge now but did use Thetford winter fridge vent covers on our caravans - think that you need to know the make & model of your fridge, take measurements of your vents as a double check then Google for which fit your particular fridge.
Not very often found a need to use fridge covers although I have them. They are usually designed for specific fridges, They can be more expensive if made for a specific marque. They are like much of Dometic/ Thetford products, not as cheap as you may expect.
First find the make and model number of the fridge.. Then lots of leisure dealers stock them and check listing on ebay.
Not cheap but sometimes you can find s'hand sets, even member on here sometimes sell when they have upgraded their vans.
No issue to use the fridge in winter without them but at low temperatures they make the fridge more effecient..
Thanks guys for advice. I thought you needed these covers on though especially in winter to stop ingress of frost?
