- Sep 25, 2009
- 827
- 1,487
- coachbuilt
- since 2004. Tugger 10 years on and off
Can someone advise me on which sikaflex for re sealing a window. I know I want a non setting mastik but not sure which one, Cheers
That is adhesive.A lot of folk use this.
Puraflex 40 PU Sealant & Adhesive
Noticing cracks or expansion in concrete? Purafelex 40 PU sealant will help you fix it quickly. It's a useful tool to have in any construction site or home, as it bonds to most materials. This product will work on concrete, wood, metal, aluminium, polyester, glass, uPVC, stone and ceramic.Thanks...www.toolstation.com
Sealant & AdhesiveThat is adhesive.
The adhesive quality is the problem. Or will be if the item one intends to seal ever requires removal.Sealant & Adhesive
But I would have thought that all sealants were also adhesives, if the sealant does not adhere to what you are trying to seal then it won't work. I have removed a roof light that was fixed with PU40 and it wasn't difficult.The adhesive quality is the problem. Or will be if the item one intends to seal ever requires removal.
I am sure it will do the job but just to emphasise my early post.Sikaflex 512 is the most suitable one.
He’s correct. I used this to (schoolboy error) refit a leaking window. It fixed the leak but I hope I never need to remove it again. I would use a none setting one next time.I am sure it will do the job but just to emphasise my early post.
Sikaflex®-512 Caravan is a strong elastic adhesive that bonds and seals in one operation
Exactly what you need when putting a window in.I am sure it will do the job but just to emphasise my early post.
